поток IP-TV
rendy
СообщениеДобавлено: Вс 5-04-09 : 14-14    Заголовок сообщения: Ответить с цитатой
Evgenius
Ну так ты вводи со всеми пробелами и подчеркиваниями. После # и после cat пробел.
# cat /proc/avalanche/avsar_modem_stats
# cat /proc/avalanche/avsar_bit_allocation_table
Evgenius
СообщениеДобавлено: Вс 5-04-09 : 14-27    Заголовок сообщения: Ответить с цитатой
BusyBox on localhost login: root
Password:
* ADSL ROUTER ACORP W422G LAN 4-PORT/WiFi *
BusyBox v0.61.Acorp (2008.04.30-06:17+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 639 DS Connection Rate: 4805
DS Line Attenuation: 26 DS Margin: 13
US Line Attenuation: 14 US Margin: 18
US Payload : 1047694032 DS Payload: 16791031
52
US Superframe Cnt : 4014508 DS Superframe Cnt: 4014508
US Transmit Power : 12 DS Transmit Power: 21
LOS errors: 0 SEF errors: 0
Errored Seconds: 1227 Severely Err Secs: 7
Frame mode: 0 Max Frame mode: 0
Trained Path: 0 US Peak Cell Rate: 1507
Trained Mode: 16 Selected Mode: 65535
ATUC Vendor Code: 4244434D ATUC Revision: 2
Hybrid Selected: 4 Trellis: 1
Showtime Count: 1 DS Max Attainable Bit Rate: 4832 kbps
BitSwap: 1 US Max Attainable Bit Rate: 875000 bps
Annex: AnxB psd_mask_qualifier: 0x0100
Power Management Status: L143 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -367
Total init. errors: 1 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 1 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 42 44 43 4d 61 9a
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 155 FEC: 0 NCD: 0
LCD: 0 HEC: 63
[Downstream (RX) Fast path]
CRC: 2362 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 21826959
Idle Cell Cnt: 81122447
Tx Packets Dropped Count: 9782
Tx Bad Packets Count: 0
[Downstream/RX)]
Good Cell Cnt: 124459801
Idle Cell Cnt: 649083061
Bad Hec Cell Cnt: 6168
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 4294469
Rx PDU's: 5768618
Tx Total Bytes: 933998472
Rx Total Bytes: 1578937034
Tx Total Error Counts: 0
Rx Total Error Counts: 311
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=15
rendy
СообщениеДобавлено: Вс 5-04-09 : 14-38    Заголовок сообщения: Ответить с цитатой
Evgenius
По второй команде?
Evgenius
СообщениеДобавлено: Вс 5-04-09 : 14-45    Заголовок сообщения: Ответить с цитатой
Password:
AR7 DSL Modem US Bit Allocation:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
06 06 06 07 08 08 08 08 07 08 08 08 08 08 08 08
08 07 07 07 07 07 06 05 04 03 00 00 00 00 00 00
AR7 DSL Modem DS Bit Allocation:
00 00 00 00 00 00 00 00 00 00 00 00 04 04 04 05
05 05 05 05 05 05 05 06 06 06 06 06 06 06 06 06
06 06 06 06 05 05 05 06 06 05 05 05 05 06 06 06
06 06 06 06 06 06 06 06 06 06 06 06 06 06 06 05
05 05 05 05 05 05 05 05 05 05 05 05 04 04 04 04
04 04 04 04 04 04 04 04 04 04 04 04 04 04 05 05
05 05 05 05 05 05 05 05 05 05 05 05 05 05 05 05
05 05 05 05 05 05 05 05 05 02 05 05 05 05 05 04
04 05 05 05 04 04 04 04 04 04 04 04 04 04 05 04
04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04
04 04 04 04 04 04 04 04 04 04 04 04 04 04 00 04
04 04 05 04 04 04 05 04 04 05 04 04 04 04 05 04
04 05 04 04 05 04 04 04 04 04 05 05 04 04 04 05
00 00 00 00 00 04 04 05 04 04 04 04 04 04 05 05
04 04 04 04 04 04 04 04 04 04 04 04 04 04 03 03
03 03 04 04 04 04 03 04 03 03 03 02 03 03 03 03
03 00 03 03 02 03 03 02 03 02 02 02 02 02 02 02
02 02 02 02 02 02 02 02 02 02 02 02 02 02 02 02
02 02 02 02 02 02 02 02 02 02 01 01 00 00 00 00
rendy
СообщениеДобавлено: Вс 5-04-09 : 15-07    Заголовок сообщения: Ответить с цитатой
Evgenius
Ну что могу сказать, во-первых, по данным показаниям, к сожалению, нельзя точно определить, какое значение BIMAX и MAXSNRM у тебя в профиле, TARSNRM у тебя 12, как видно из параметров линии.
ATUC Vendor Code: 4244434D - BDCM Broadcom (чипсет DSLAM).
Что можешь сделать со своей стороны - заменить комплектный телефонный кабель от Acorp (с ним возможно ослабление сигнала), протянуть от щитка в подъезде до сплиттера витую пару UTP кат 5e.
По поводу профиля - звонить 062, FAST при подключении IpTV отключить в любом случае, картинка с таким количеством ошибок CRC будет сыпаться. Если попадёшь на квалифицированного оператора техподдержки, то попробуй разобраться с профилем (target SNR Margin сейчас 12, скорость поднять сейчас в любом случае можно, выставив профиль 10-6 или 6-0, вопрос в том, на сколько и как будет со стабильностью в этом случае).
Обнови прошивку модема, используй последнюю версию прошивки с версией DSP 7.0 http://ddixlab.ru/acorp/adsl/ti-2.x/
Evgenius
СообщениеДобавлено: Вс 5-04-09 : 15-24    Заголовок сообщения: Ответить с цитатой
rendy
у меня телефон спаренный,кабель новый от щитка на втором этаже тянул мастер!что за профиль 10-6 6-0?какая скорость?
rendy
СообщениеДобавлено: Вс 5-04-09 : 15-26    Заголовок сообщения: Ответить с цитатой
Evgenius
Со схемой подключения точно всё в норме? Сплиттер где находится?
Evgenius
СообщениеДобавлено: Вс 5-04-09 : 15-29    Заголовок сообщения: Ответить с цитатой
со схемой должно быть всё в норме,сплиттер как я понял на втором этаже в щитке,т.к. у соседей сигналка!вроде ничего не менялось с того момента как я подключисля,а скорость упала!
rendy
СообщениеДобавлено: Вс 5-04-09 : 15-44    Заголовок сообщения: Ответить с цитатой
Evgenius
Хм, спаренный телефон + сигналка у соседей?
Трудно сказать сейчас, что именно в твоей ситуации. Сейчас самое главное попасть на нормального специалиста в 062, который посмотрит, что именно у тебя там выставлено и сделает всё необходимое для поднятия скорости. Затухания-то небольшие, соответственно, надо искать причину, почему скорость не поднимается (spectrum-profile?).
Lemonad88
СообщениеДобавлено: Ср 8-04-09 : 12-59    Заголовок сообщения: Ответить с цитатой
Скажите, а на Муз-тв (12 какнал) звук у всех рвет или только у меня?
AstraL
СообщениеДобавлено: Ср 8-04-09 : 19-00    Заголовок сообщения: Ответить с цитатой
Не только у тебя, у меня тоже, причем на всех каналах.
jon222
СообщениеДобавлено: Вт 21-04-09 : 19-25    Заголовок сообщения: Ответить с цитатой
хочю подключить услугу твист, тел. кабель в нескольких местах порван и сцеплен кустарным способом...( инет при этом идет нормально, будет ли нормально идти телевидения с такими параметрами ( пакет стандарт) 062
 Размер файла:  227.26 KB
 Просмотрено:  310 раз(а)
Последний раз редактировалось: jon222 (Ср 22-04-09 : 00-08), всего редактировалось 1 раз
PILOT
Матёрый
СообщениеДобавлено: Вт 21-04-09 : 19-36    Заголовок сообщения: Ответить с цитатой
jon222
У вас видимо ДСЛАМ в подъезде стоит Smile
Нормально должно пойти.
А профиль можно повысить. Мегабит 20 может быть.
Minister
СообщениеДобавлено: Пт 8-05-09 : 17-48    Заголовок сообщения: Ответить с цитатой
У меня профиль 6000/600 .. Но IP-TV мне так и не хотят подключать...
Типа оборудование у них не позволяет...
Для тв же ненадо спецоборудования на стороне оператора???
Alarus
СообщениеДобавлено: Вт 12-05-09 : 17-05    Заголовок сообщения: Ответить с цитатой
чтото маловато этих 10 каналов , rendy когда там шифрованый контент без приставки смотреть сможем ?
rendy
СообщениеДобавлено: Вт 12-05-09 : 17-25    Заголовок сообщения: Ответить с цитатой
Alarus
Без понятия, вопрос не ко мне.
BorPas
Девелопер
СообщениеДобавлено: Вт 12-05-09 : 17-27    Заголовок сообщения: Ответить с цитатой
хоть щас topic35466
Alex_ya77
СообщениеДобавлено: Вт 19-05-09 : 09-30    Заголовок сообщения: Ответить с цитатой
Скажите пож. у меня при включении приставки , падает скорость на внутрисетевых ресурсах до 2- 2.5 Mb, так и должно быть?
BorPas
Девелопер
СообщениеДобавлено: Вт 19-05-09 : 13-19    Заголовок сообщения: Ответить с цитатой
ну да, профиль дефолтный 8 мегабит, канал весит 4-5 мегабит, 8-5=3 остаётся на интернет
Alex_ya77
СообщениеДобавлено: Вт 19-05-09 : 18-13    Заголовок сообщения: Ответить с цитатой
ясно спасибо
Страница 2 из 2
