SpeedWay Озверевший Гонщик Предупреждений : 6
Сделал смарт тесты своих винтов в виктории
Подскажите, есть ли повод беспокоиться?
ST3500320AS 5QM1G4WY
ID Name Value Worst Tresh Raw Health
1 Raw read error rate 115 99 6 91585483 •••••
3 Spin-up time 94 91 0 0 ••••
4 Number of spin-up times 99 99 20 1362 ••••
5 Reallocated sector count 100 100 36 0 •••••
7 Seek error rate 72 60 30 16746806 •••
9 Power-on time 97 97 0 2815 ••••
10 Spin-up retries 100 100 97 8 •••••
12 Start/stop count 100 100 20 619 •••••
184 End-to-End error 100 100 99 0 •••••
187 Reported UNC error 100 100 0 0 •••••
188 Command timeout 100 100 0 0 •••••
189 High Fly writes 100 100 0 0 •••••
190 Airflow temperature 61 53 45 39°C/102°F ••••
194 HDA Temperature 39 47 0 39°C/102°F ••••
194 Minimum temperature 90 47 0 20°C/68°F -
195 Hardware ECC recovered 45 26 0 91585483 ••
197 Current pending sectors 100 100 0 0 •••••
198 Offline scan UNC sectors 100 100 0 0 •••••
199 Ultra DMA CRC errors 200 200 0 0 •••••
ST3320620AS 6QF0YC0N
1 Raw read error rate 118 100 6 167965481 •••••
3 Spin-up time 96 96 0 0 ••••
4 Number of spin-up times 99 99 20 1484 ••••
7 Seek error rate 81 60 30 151421397 ••••
9 Power-on time 95 95 0 5078 ••••
10 Spin-up retries 100 100 97 0 •••••
12 Start/stop count 99 99 20 1479 ••••
190 Airflow temperature 60 48 45 40°C/104°F ••••
194 HDA Temperature 40 52 0 40°C/104°F ••••
194 Minimum temperature 90 52 0 18°C/64°F -
195 Hardware ECC recovered 74 55 0 235495300 •••
199 Ultra DMA CRC errors 200 200 0 1 •••••
200 Write error rate 100 253 0 0 •••••
202 DAM errors count 100 253 0 0 •••••
WDC WD7501AALS-00J7B0 WD-WMAU00028137
1 Raw read error rate 100 253 51 0 •••••
3 Spin-up time 253 253 21 5900 •••••
4 Number of spin-up times 100 100 0 8 •••••
5 Reallocated sector count 200 200 140 0 •••••
7 Seek error rate 200 200 0 0 •••••
9 Power-on time 100 100 0 2 •••••
10 Spin-up retries 100 253 0 0 •••••
11 Recalibration retries 100 253 0 0 •••••
12 Start/stop count 100 100 0 6 •••••
192 Power-off retract count 200 200 0 5 •••••
193 Load/unload cycle count 200 200 0 8 •••••
194 HDA Temperature 107 107 0 43°C/109°F ••••
196 Reallocated event count 200 200 0 0 •••••
197 Current pending sectors 200 200 0 0 •••••
198 Offline scan UNC sectors 100 253 0 0 •••••
200 Multi zone error rate 100 253 0 0 ••••• |
zmeeed Эксперт |
zmeeed писал(а): |
ЗЫ Поздравляю с покупкой винчестера |
Пасиба))
zmeeed писал(а): |
http://ru.wikipedia.org/wiki/SMART читаем, думаем, беспокоимся |
Эх.... бум читать... |
SpeedWay писал(а): |
195 Hardware ECC recovered 45 26 0 91585483 •• |
меня больше всего это интересует... систему не разгонял... |
sog Гуру |
SpeedWay
для сигейтов это нормально, если рядом с первым аттрибутом |
sog писал(а): |
Как это рядом с первым атрибутом? Какой атрибут имеется ввиду? |
sog Гуру |
Raw read error rate
эх, сигейт |
k0stE Гуру |
SpeedWay, не проще скриншотом выложить ? )))))))))))) |
sog Гуру |
k0stE
Открою тайну. В виктории есть копирование лога в буфер. Это он не сам набивал))) |
k0stE писал(а): |
Окошко виктории маловато, весть лог не входит
sog писал(а): |
Так оно и есть)) |
k0stE Гуру |
sog писал(а): |
k0stE
Петросян?
k0stE писал(а): |
Окошко виктории маловато, весть лог не входит |
А это чит?) |
sog Гуру |
k0stE
На твоем скрине слишком много избыточной информации. Оптимизируй |
k0stE писал(а): |
А это чит?) |
У меня информации выводит побольше и там появляется полоса прокрутки, окно не увеличивается.... |
