Музыкант Админ |
6.45 Changelog:
* Recoded Avatar on Black King Bar to fix various engine bugs (control loss, model glitches, etc)
* Fixed Lightning Storm tooltip
* Increased Barrier cooldown
* Improved cast range on Lightning Grapple
* Surge no longer purges target
* Increased Laser mana cost from 95/110/120/145 to 95/120/145/170
* Rebalanced Refraction
* Reduced the slow effect on Dirge's Plague
* Remade Pit Lord's ultimate
* Fixed Death Timer showing up after game is over
* Nightstalker's Crippling Fear now has a minor effect during the day
* Added an extra bounce to Scepter upgraded Chain Frost
* Lowered Meld mana cost
* Increased Templar's base attack range by 10
* Increased Refraction cooldown a little
* Fixed minor display glitch with -di
* Reduced Primal Split manacost from 150/225/320 to 125/175/225 and increased duration from 15 seconds to 15/20/25
* Improved Acid Spray AOE and Cast Range by 75
* Increased Drow's Silence AOE from 250 to 275
* Added new icon for Storm (148340)
* Improved Dragon Knight's Agility base and growth
* Lowered Overgrowth mana cost from 200/250/300 to 150/175/200
* Fixed Overgrowth to work on units in fog
* Changed Vengeful Spirit's Terror hotkey to E
* Improved Nightstalker cast animation time
* Fixed the canceling of Clarity Potion bug on Death Pulse
* Scroll of Town Portal can now target the World Tree/Throne
* Improved Sniper's Agility growth a bit
* Changed level 3 Chemical Rage Base Attack Cooldown from 1.25 to 1.20
* Improved Frost Armor
* Issues with droppable BKB resolved, it can now be dropped
* Reduced mana cost on Death Pact slightly
* Rebalanced Voodoo Restoration
* Fixed -unstuck bug at the end of the game
* Fixed some bugs with the display names of the courier killer
* Improved Vladmir's Offering recipe tooltip
* Fixed various Flying Courier tooltip errors
* Increased Vulture model size a bit
* Fixed Shadow Priest appearing in allstr and allagi
* Vastly increased Eyes in the Forest cast range
* Fixed the heal on Dirge's Zombies from canceling Clarity Potion
* Fixed various terrain glitches
* Changed Shadow Word damage type to Magical from Pure but adjusted the damage so it remains the same (unless you have extra magic resistance). The overall dps hasn't changed much, only its mechanics with different bonus resistances.
* Added code to prevent Couriers with invulnerability shield from entering enemy fountain areas to steal items
* Rewrote Smoke Screen to fix various minor visual glitches
* The time hero left at is now shown in -ma (146489)
* Fixed Ring of Basilius tooltip when you change its operating mode
* Fixed Stygian Desolator buff icon
* Changed Raise Revenant icon
* Added Victory Animations for units at the end of the game (150018)
* Clarified Gravekeeper's Cloak tooltip
* Rewrote Battle Hunger to fix an engine buff conflict with Gush and Hunger at same time
* Fixed various minor leaks
* Prioritized 2xror over roh in if you have all 3 in your inventory when creating Hood of Defiance so it doesn't use up your RoH
* Improved Living Armor a bit
* Fixed various other tooltip errors
* Clarified Eclipse tooltip
* Changed the Rock Golems that spawn in pairs (the ones that aren't in the ancient spawn points) to non-ancient type
* Fixed Sange and Yasha Maim buff icon
* Added new icons for Aftershock, Plague Wards, Overload and Grapple (thanks snork,Faust-,^SnakeZer0,1Raven and eva00r)
* Removed the dispell effect from Overload (too many undesired effects from both sides to be passively occuring)
* Bloodstone now gives you bonus health and mana regeneration for each charge it has on it
* Added new command -hideheronames to disable the new hero name display in chat functionaly. This is useful when you are trying to squelch someone and bnet won't let you.
Аватар с BKB теперь исправляет баги движка(потерю контроля, глюки моделей...)
* Исправлено описание Lightning Storm
* Увеличена длительность перезарядки Barrier
* Увеличена дальность колдования Lightning Grapple
* Surge больше не purgит цель
* Увеличена стоимость Laser с 95/110/120/145 маны до 95/120/145/170 маны
* Переделана Refraction
* Уменьшено замедление на Plague героя Dirge
* Новый ульт Pit Lord'а
* Death Timer теперь не уменьшается после окончания игры
* Crippling Fear Nightstalker'а теперь слабо работает днём
* Chain Frost Лича с Аганимом прыгает ещё раз.
* Уменьшена стоимость Meld до 50
* Дальность атаки Templar увеличена на 10
* Чуть-чуть увеличена длительность перезарядки Refraction
* Убран глюк экрана с -di
* Уменьшена стоимость Primal Split с 150/225/320 маны до 125/175/225 маны и увелична длительность с 15 секунд до 15/20/25 секунд
* Увеличена дальность и AOE Acid Spray на 75
* Увеличен AOE заклинания Silence Drow Ranger с 250 до 275
* Новая иконка Storm (148340)
* Увеличена базовая ловкость Dragon Knight и её прирост
* Уменьшена стоимость Overgrowth с 200/250/300 до 150/175/200
* Исправлен глюк с Overgrowth и юнитами в тумане
* Изменена горячая клавиша способности Terror героя Vengeful Spirit на E
* Увеличена длительность анимации колдования Nightstalker'a
* Исправлен глюк с отключением Clarity Potion при Death Pulse
* Свиток Телепорта теперь может перекидывать к Дереву\Трону
* Увеличен прирост ловкости Sniper
* Уменьшен cooldown атаки на 3 уровне Chemical Rage с 1.25 до 1.20
* Усилена Frost Armor Лича до 12
* БКБ теперь можно выкидывать
* Death Pact теперь стоит чуть меньше маны
* Voodoo Restoration изменена с 24 до 30
* Исправлен глюк с -unstuck в конце игры
* Исправлен глюк с отображением имён убийц животных-курьеров
* Улучшено описание рецепта Vladmir's Offering
* Исправлены ошибки в описании Flying Courier
* Чуть-чуть увеличена модель Vulture
* Shadow Priest больше не появляется в allstr и allagi
* Увеличена дальность использования Eyes in the Forest
* Лечение от Zombies героя Dirge теперь не отменяет Clarity Potion
* Исправлены глюки с рельефом
* Shadow Word теперь наносит магический урон вместо чистого но урон изменён, так что он остался почти тем же, если у героя нет доп. сопротивления к магии
* Курьеры под неуязвимостью теперь не могут подходить к вражескому фонтану.
* Переписан код Smoke Screen для удаления зрительных глюков.
* Время, на котором игрок ливанул теперь показывается в -ma (146489)
* Исправлен глюк с описанием Ring of Basilius
* У Stygian Desolator теперь другая иконка
* У Raise Revenant теперь другая иконка
* Юниты теперь проигрывают свою "победную анимацию" в конце игры
* Изменено описание Gravekeeper's Cloak
* Исправлен глюк с Battle Hunger и Gush
* Исправлено множество мелких утечек памяти
* Теперь если у вас в инвентаре есть 2 RoR и 1 RoH и вы создаёте Hood of Defiance RoH не исчезает
* Усилена Living Armor
* Исправлено множество мелких глюков с описаниями
* Изменено описание Eclipse
* Теперь Rock Golems(которые появляются парами и не стоят на точке появления других ancient'ов) не ancient'ы
* Исправлена иконка Maim от Sange and Yasha
* Новые иконки для Aftershock, Plague Wards, Overload and Grapple (спасибо snork,Faust-,^SnakeZer0,1Raven and eva00r)
* Overload больше не снимает заклинания
* Bloodstone теперь даёт бонусный хп- и манареген за каждый свой заряд
* Новая команда -hideheronames чтобы убрать показывание имён героев в чате. |
†ORC† Адский Черепок |
Выложите плис новейшую доту с ботам!.. |
Музыкант Админ |
Amaterasu Uchiha Avenger Предупреждений : 2
6.48b
6.48b.zip |
Описание: |
Скачать |
6.48b.zip |
Размер файла: |
2.37 MB |
Скачано: |
445 раз(а) |
Вовка Цепкая Рука Продвинутый форумчанин |
Kirya Форумчанин |
0)а у кого есть полная версия ДОТЫ??
1)Расскажите пожалуйста что за игра?
2)какие особенности??
3)как подключаться к серву??
4)мнооли играет там народу?
5)бесплатно ли играть?? |
Музыкант Админ |
0)что имел ввиду под "полная версия"? ДОТА это карта для игры Варкрафт3. getdota.com тут скачать карту(так же с ботами)
1)ДОТА это карта для игры Варкрафт3. играешь 1м героем и месишь героев врагов. максимум 5Х5
2)всех не перечислишь
3)5)http://www.adslclub.ru/forum/viewtopic.php?t=1656
4) на Цн ПГ и ОФФсерверах много |
asaa Начинающий |
Народ заходите http://mydota.forum24.ru/
Я создал форум на тему Дота нужна вашая поддержка!
Напишыте разные статти на тему дота и варик на моем форуме! |
