Snake Форумчанин |
Некоторое кол-во реплеев от топ-команд, которые посмотрел сам и увидел много интересного.
1. Обратите внимание на героев вроде Невермора, Лины и Тинкера.
2. Обратите внимание на "нечестную" тактику 3-на-линии.
3. Обратите внимание на связки вроде сайленсер+ск.
ссылка: http://file.risp.ru/get/file/?id=44855 |
Snake Форумчанин |
Logotip Форумчанин |
пиши плз что за репки, кто с кем,а то много что есть, путаюсь (( |
Pechalen Форумчанин |
Сходите на www.Dotacraft.ru там реплеев про команд полно.Последний кстате один из многих.Да и вообще,если большие фанаты доты там много чё можно почитать найти интересного.
Obscura #1 from URgunnaDIEclown
The green selection circle, which is of different sizes for every hero, is purely cosmetic. It has nothing to do with collision size. In fact, all heroes have same collision size of 24.
from Erazer: Metaform Soul Keeper has collision size 22.
Obscura #2 from URgunnaDIEclown
The Crystal Maiden's freezing field strikes within a square area (not circular), will never detonate centered on her, is more concentrated closer to her, and is less concentrated along the diagonals. Thus, it is not randomly distributed at all!
Confirmed by Virot2.
Obscura #3 from URgunnaDIEclown
DotA uses a custom armor/attack type interaction table over the standard War 3.
from Erazer:
Chaos deals 40% to Fortified, instead of 100%
Ethereal takes 44% extra, instead of 66%
Normal deals 125% to Heavy, instead of 100%
Normal deals 75% to Hero, instead of 100%
Siege deals 125% to Heavy, instead of 100%
Siege deals 63% to Hero, instead of 50%
Siege deals 130% to Unarmored, instead of 150%
Spells deal 75% to Hero, instead of 70%
I'll try to update this daily.
Obscura #4 from Sir Rogers
Dazzle's ultimate revives in 25% of the time, not 20% as stated.
Obscura #5 from Sir Rogers
When using Medusa's spell shield, if spell shield is on when you are silenced, spell shield will stop functioning even though it says it is on. You must cancel and recast for it to work.
Obscura #6 from Sir Rogers
If you have Luna and you shoot off the second Glaive before the first one hits (due to high attack speed), the Glaives will bounce back and forth on two targets, neglecting the rule that they can't bounce on targets they have hit before.
Confirmed.
Obscura #7 from Sir Rogers
Astral Imprisonment and Chronosphere pause any effects on the heroes affected by it. So you can't save an ally by casting it on them to save from a damage over time. The dot counter is merely paused, these affects do not run down the clock. However, hero regen continues, which might save the hero.
Obscura #7 from semihalfwit and Spacewhizguy
In -wtf mode, casting nightmare or astral imprisonment on yourself will kill you if you don't issue a command after the cast.
Obscura #8 from Spacewhizguy
Medusa's mana shield when active will convert negative damage, such as from ally's Death Pulse, to mana and will not regain HP.
Obscura #9 from k9burn
Ghouls can be dominated by sentinel players, and then used to harvest lumber from trees. One hit will destroy eyes of the forest on a tree.
Obscura #10 from Trixbeat
Images can bash. However, this is a fake bash, which does not prevent movement.
If a hero is bashed or fake bashed and receives another bash or fake bash, the original bash or fake bash will be prolonged. Thus, images can help perma stun if the first stun is from the hero. If the first stun is from an image, the hero will have perma fake stun.
Obscura #11 from Xagest
If an enemy uses BOT on a creep, and then Chen (on the other team) dominates that creep and teleports the creep back to his own fountain, the enemy hero will end up in Chen's fountain (and most likely be killed by the fountain).
Obscura #12 from Gotham
Rhasta's wards do a small amount of splash (AoE damage).
See this thread.
Obscura #13 from clogon
Berserker's Rage is based on Bear Form and not Metamorphasis. This is why when you manta with Troll or Sylabear, you remain in the form that you are instead of changing back to your original form.
Obscura #14 from clogon
Illusions/images with Eye of Skadi throw fake frost attacks. The missile changes to frost attack, but does not slow.
Obscura #15 from hopecount
When impaled/burrowstriked and in air you are invulnerable; you cannot be targetted or damaged. This breaks attack commands of heroes attacking you. (From theAlice: Clicking on units in the air gives an error message.)
When under frostbite you cant be impaled/burrowstriked.
from Jos: After landing from impale or burrowstrike, while stunned you cannot be hit by impale or burrowstrike again.
Obscura #16 from clogon
You can target people with spells and ranged attacks that are being tossed by Tiny.
Toss will still activate even there is no one to toss and you will waste your mana and CD.
from URgunnaDIEclown: in order to toss, you have to have a unit under the targetting recticle, otherwise it does not toss the unit. You can toss to yourself (and you can hit them in mid air, too!)
Obscura #17 from Jos
If you get Hood of Defiance / Plainswalker's Cloak BEFORE LEARNING Flesh Heap/Spell Shield, the magic resistance bonuses will stack will stack with themselves, and with hero natural spell resistance (Dimishingly)
Obscura #18 from theAlice
Vengeful Spirit's attack projectiles can be hooked by Pudge. It could be uhh...useful if your friend only has enough HP to take one more hit. >_>
Obscura #19 from theAlice
If you cast Avatar just as a chronosphere is going up, it won't freeze you.
Obscura #20 from theAlice
In -wtf mode, issuing cast orders for Avatar in conjunction with Manta Style together will make you lose control of your hero.
Obscura #21 from theAlice
In -wtf mode, Leoric can be killed if you prevent him from casting any spells (and thus resetting his reincarnate cooldown).
Obscura #22 from theAlice
(Unless this has changed with the new Roshan) Images die instantly when they try to hit Roshan.
Obscura #23 from theAlice
If you collect a rune with your bottle, your bottle will be filled once you use the rune.
Obscura #24 from theAlice
Axe's Culling Blade goes through Abbadon's Ultimate.
Obscura #25 from theAlice
Magnus' Reverse Polarity is triggered and therefore goes through magic immunity. It also works on units who have left the surrounding area, as long as they were next to Magnus when he started casting. (You can have Haste and be half a screen away, but if you were near Magnus when he started casting, you'll still pop up next to him.)
Obscura #26 from theAlice
If you attack a unit from fog of war where they can't see you, they gain vision of you. (This really gets annoying when you're playing sniper.)
Obscura #27 from theAlice
The command -Disablehelp turns off Chen's ability to teleport you home.
Obscura #28 from Arcykutas
If Enigma cast Malefice on you, you wont be able to cast some spells before Malefice ends. Panda's primal split is one of those spells.
Obscura #29 from Arcykutas
Pudge and Vengeful Spirit CAN use dagger, but they will drop it just after use.
Obscura #30 from Arcykutas
Tinker's rearm works on all spells from items, excpet arcance ring, blah, and blah.
Obscura #31 from Arcykutas
If doom use devour on creep that is moving, he will miss that unit, and devour mana/cd will be wasted.
Confirmed.
Obscura #32 from Arcykutas
Using omnislaslash on teleporting hero may result in teleporting with him. (Works on Prophet teleport, I am not sure about BoT).
Obscura #33 from Arcykutas
There are places on map that you cant reach them w/o blink. So you can blink there by for example antimage, than Vengeful Spirit can swap him and is waiting for enemy to swap again.
from clogon: Players who are stuck in such a way can use -unstuck command to channel for 60 seconds and return to fountain.
You can hook or swap a player under effects of fiend's gripped, but it wont break grip effect.
Obscura #34 from Guyoverthere07 and thailehuy
Rhasta's shackle, Fiend's grip, and Pudge's dismember cannot be cast at the same time on a unit, because they are all based on the aerial shackle ladder spell.
Obscura #35 from clogon
Charge of darkness allows Spirit Breaker to go through trees and up cliffs just like Specter with Dagger. However, the pathing AI, which is automatically used, still avoids these obstacles. However, you can use it to go through other barriers, such as creep block, other heroes, Rhasta's ward trap, and Prophet's Sprout.
Obscura #36 from lozenge1
Using BoT to teleport to an allied creep breaks its auto-attack command. So if there are no enemies nearby, it will simply stand still until some come within aggro. If in a group that is fighting, it will continue with the group.
Вот это оттуда.Переведите ктонить,тут много полезного. |
Snake Форумчанин |
Только зачем это в реплеях-то выкладывать?
Насчет дотакрафта - я там часто беру реплеи, сюда выкладываю из-за того, что траффик нетарифицируется. Зачем по сто раз качать одно и тоже платно? Да еще гребаному NS'у траффик генерить =) нет уж! |
А перевести сможет кто?А то в этом деле слаб.Там полезная инфа,думаю лишней не будет.Дотеров просветить. |
А вот и перевод:
1.Зеленый круг выбора, который имеет различные размеры для каждого героя, просто для вида. Это не имеет никакого отношения к размеру . Фактически, все герои имеют тот же самый размер 24. от Erazer: Хранитель Души Metaform имеет размер 22.
2. Ульта Кристалки абсолютно рандомна, единственное, что ближе к ней взрывы имеют большую концентрацию, чем по краям
3. DotA использует свою систему взаимодействия типов брони/нападения нежели в стандартном варике3
Chaos атака наносит 40% по Fortified броне вместо 100%
а по Ethereal броне входит на 44% дамаги больше, вместо 66%
Normal атака наносит 125% по Heavy броне, вместо 100%
Normal атака наносит 75% по героям, вместо 100%
Siege атака наносит 125% по Heavy броне, вместо 100%
Siege атака наносит 63% по героям, вместо 50%
Siege атака наносит 130% по Unarmored, вместо 150%
Заклинания наносят 75% по героям, вместо 70%
4. Ульта Даззлера скоряет время реса на 25%, а не на 20%, как показано в описании скила
5. Если на медузу в Манашилде вешается сайленс, шит перестает функционировать, и бездейстует, пока медуза его не перекастит или не подохнет =)
6. Если у вас есть Луна и вы успеваете выстрелить в цель вторым глэйвом прежде, чем до нее долетит первый(должна быть высокая АСПД), то оба глэйва будут скакать по двум целям, пренебрегая правилом, по которому они не могут бить цели, по которым они уже били.
7. В -wtf моде, каст nightmare Или astral imprisonment на самого себя убьет вас, если не пропишите какую-то команду (хз, не совсем понял))
8. Mana Shield медузы преобразует негативный дамаг, как например Dead pulse от союзника, в ману и не восполняет хп
9. При желании можно переманить гулек и застаить их собирать дерево, 1 удар по дереву разрушит глаз, на нем висящий
10.Иллюзии могут башить, однако это фэйк(ненастоящий баш, противник не станится) Однако, если герой застунен настоящим башем, баш с иллюзии продлевает его. Таким образом иллюзии могут помогать держать противника в пермабаше. Однако если первый баш был с иллюзии, то весь пермабаш будет фейком и герой будет двигаться
11.Если противник юзает БОТ на крипа, а Чен из другой команды переманивет этого крипа и телепортит на свой фонтан, то герой, делающий ТП улетит следом на фонтан чена и наверняка сдохнет там
12. Варды Расты бьют сплэшем
13. Berserkers Rage основан на Bear form, а не на Metamorphasis. ИМенно поэтомц, когда вы юзаете манту Троллем или Медведом, вы остаетесь в той форме, в которой были, не изменяясь в вашу первоначальную форму
14.Во время Empale/Burrowstrike и в воздухе вы неязвимы. На вас не могут навести цель или нанести урон. (От Алиски)Кликая на юниты в воздухе, вы рискуете получить ошибку.
Когда вы в кристалкиной заморозке, на вас можно юзать и empale и burrowstrike.
Джос говорит, что после приземления от empale /burrowstrike , пока вы стоите в стуне, вас нельзя опять подкинуть empale/burrowstrike снова
15. Вы можете атаковать цели , которые летают от тосса Тини.
Бросок активируется, даже если рядом некого бросать, и вы впустую тратите ману и кулдаун
from URgunnaDIEclown уверен, что для успешного тосса нужна цель(кого подкинуть) и вторая цель(на кого это кинуть). При этом этими двумя целями может быть один и тот же юнит, и если вы его подкидываете на месте, то во время полета его еще и можно побить=)
16. Если вы возмете ХУД (оказывается переводится как Капюшон Вызова=))/клоку перед тем, как выучите Flesh Heap/Spell Shield, то все бонусы антимагии будут друг с другом и с родным резистом героя
17.Иллюзии со скадей не замедляют, хот и показывается анимация заморозки
18. Пудж может крюком поймать анимацию атаки Венги. полезно, если вы пудж, а ваш друг 10хп убегает от спиритки
з.ы. фигня имх))
19. Вы можете заюзать Аватар в момент разворота купола и не заморозиться...
20. Если в -wtf моде спамить аватар, то вы потеряете контроль над героем, и никакие манты там не нужны, я сам проверял =)
21. В -wtf моде, Леорика можно убить, если помешать ему кастовать, тогда у него сбрасывается кулдаун на ульту.
22. Иллюзии дохнут, когда пытаются убить рошана. Некрономиконцы Рошана не бьют.
23. Если вы возмете руну в бутылку, то ваша бутылка будет заполнена, как только вы используете руну.
24. Ульта Аксы проходит через ульт Шавермуса(Авернуса=))
25. Ульта Магнуса очень крутая, потому от нее не спасают резисты от магии. Если цель в момент начала каста была в АоЕ ультима, то он сработает на нее, несмотря на сколько цель успела убежать.
26. Если вы стреляете по противнику из тумана войны, он начинает вас видеть. Снайпер ... ... демона =)
27. команда -disablehelp не позволит Чену отправить вас домой и спасти от врагов=(
28. Если Энигма кидает на вас Malefice, вы не можете кастить некоторе спеллы. Primal Split у Панды как раз один из таких спеллов.
29. Пудж и Спиритка могут юзать даггер, но он выпадет сразу после использования
30. Ульта Тинкера работает на все шмотки, кроме арканки бла и бла Oo
31. Если дум попробует сожрать двигающегося крипа, то ничего не получится, он тлько потратит ману и получит кулдаун
32. Ульта Джаггера, на героя делающего ТП, приведет к тому, что джаггер улетит вместе с ним, то же самое с баратрумом
33.абузы нах
34. Charge of darkness позволяет Спирит Брейкеру проходить через деревья и горы как Спектре с даггером. Однако АИ обычно обходит эти препятствия. Однако это можно юзать, чтоб проходить другие барьеры, а ля крипблок, другие герои, Варды расты, деревья фуриона
35. Вы можете притянуть/свапнуть героя, который находится под ультой Бэйна, но это не снимет эффект ульты
36. Варды Расты, Грип Бэйна, и Пуджевский дисмембер не могут быть скастованы одновременно на цель, потому что они все какие-то мощные =)
37. Использование БоТ прерывается, если нажать автоатаку. Делаем выводы |
на дотакрафте мало че полезного, там просто прикольно, если интресно, то на dotapick.ru гораздо больше полезной инфы, но не вся она верная |
20 минутный реплей, показательный такой, всем смотреть |
Snake Форумчанин |
Дема туповатая, но фб отличный =))) |
Smouk Бывалый |
Snake
Ахахаха, чем то мне это напомнило Виталю!!! Ром, муз гляньте обязательно. Вобще кора |
Серега_Серега Продвинутый форумчанин |
Играли мы кароче ...
Сало собрал СиЯ (в симье ни без урода) - ЭТО НИ Я !!!!
все маги (стас баран) !! =)).rar |
Описание: |
Скачать |
Размер файла: |
382.72 KB |
Скачано: |
594 раз(а) |
Мда,действительно:в семье не без урода. |
Smouk Бывалый |
Миранка))
Миранка.rar |
Описание: |
Скачать |
Миранка.rar |
Размер файла: |
747.93 KB |
Скачано: |
581 раз(а) |
Smouk Бывалый |
реплеи
replays.rar |
Описание: |
Скачать |
replays.rar |
Размер файла: |
1.91 MB |
Скачано: |
587 раз(а) |
Smouk Бывалый |
последняя игра клана e3a (ps состав не основной, так что строго не судите )
)).rar |
Описание: |
Скачать |
)).rar |
Размер файла: |
648.31 KB |
Скачано: |
567 раз(а) |
это с чампа? пффф, нашел че выложить |
Smouk Бывалый |
e3a vs SSb (думаю вождь обрадуется)
e3a def ssB.rar |
Описание: |
Скачать |
e3a def ssB.rar |
Размер файла: |
783.95 KB |
Скачано: |
588 раз(а) |
Вождь обрадуется,факт.Игра,кстате,закончилась токо час назад.
Для тех кто не в курсе:это игра с онлайн чемпионата,стартовавшего на днях.Игра групповой стадии.Участвует 28 команд со всей России .ССБ-фавориты,кстате.Все доединого,насколько мне известно,студенты МГУ .Первую игру нет смысла выкладывать:у е3а в самом начале слететел 1вояка ,моксвичи от рестарта отказались,падонки.Вот и всё.
Продолжение следует ........ |
Smouk Бывалый |
пара игр с ггц
replay.rar |
Описание: |
Скачать |
replay.rar |
Размер файла: |
959.15 KB |
Скачано: |
598 раз(а) |
