Norton SystemWorks 2007 Premier + Keygen
Big Digger
СообщениеДобавлено: Вс 15-07-07 : 08-40    Заголовок сообщения: Norton SystemWorks 2007 Premier + Keygen Ответить с цитатой
ftp://ftp.nsk.in/upload/SOFT/NORTON.SYSTEMWORKS.2007.PREMIER.EDITION-EDGEISO/
CD1: Norton SystemWorks 2007 Premier
CD2: Norton Recovery Disc (bootable disc)
INSTALLATION INSTRUCTIONS
1. Unrar, Burn or mount with Daemon Tools.
2. DISCONNECT FROM THE INTERNET! THIS IS IMPORTANT!
3. Run the installer, and run the keygen located in the EDGE dir.
4. Copy the Product Key from the keygen to the Norton Setup then press
the I Agree button..
5. Complete installation and finally you will get to the activation,
it's important that you are NOT connected to the Internet!
Press the Next button.
6. A message box will come up telling you that you need Internet
connectivity to continue, just press the OK Button, and then press
the Next button.
7. You will get to a part where it's trying to connect to the Internet
for online activation, after a while it will fail, this is fine,
repeat this step again.
8. After attempting to do online activation two times, it will fail.
9. Select Phone Activation and press press the Next button.
10. Now copy the 36 digit Request Code into the Request Code field in
the keygen, no dashes or spaces just one long 36 digit string.
Select how many years you want to license the software for, and
press the Generate button to get your Unlock Code.
11. Copy the generated Unlock Code to the Norton activation screen,
then press the Next button.
12. Enjoy a fully unlocked copy, and naturally DO NOT register this
software with Norton, you can now reconnect to the Internet.
Последний раз редактировалось: Big Digger (Вс 15-07-07 : 21-59), всего редактировалось 1 раз
cryimer
СообщениеДобавлено: Вс 15-07-07 : 09-05    Заголовок сообщения: Ответить с цитатой
Big Digger
Еще бы историю изменений если можно и отзыв, если ставил
Big Digger
СообщениеДобавлено: Вс 15-07-07 : 20-24    Заголовок сообщения: Ответить с цитатой
сам пока не ставил... просто вчера на NSW2006 слетела активация нулями, а тут новая версия с нормальным кейгеном - на руборде говорят все шоколадно
Powerful protection and performance enhancement
* Norton AntiVirus™
* Norton™ Save & Restore
* Norton Utilities™
* Norton GoBack™
* One Button Checkup
* System Optimizer
Key Features
* Detects and removes viruses and spyware
* Blocks spyware and worms automatically
* Prevents virus-infected emails from spreading
* Finds and removes hidden threats
* Backs up everything on your computer—digital photos, family videos, key financial records, essential computer system files, and other data—in one easy step.
* Protects all files of a certain type (such as photos or documents) by finding and backing up the exact file types you indicate.
* Automatically detects and fixes Windows problems
* Defragments and optimizes your hard drive for better performance
* Cleans up unwanted cookies, cache, and temporary files that slow your computer's performance
* Gives you control over the Windows settings and processes running on your system
* Returns your computer to a pre-crash state after system failures and other major problems
* Recovers individual folders, files, and previous document versions, even if you forget to save them
* Monitors new software installations and reverses the installation if you decide you don't want the software
* Includes protection updates and new product versions of this product as available throughout the renewable service period*
* On-going Protection keeps your computer protected from the latest Internet risks by automatically renewing your subscription at the regular subscription price (plus applicable tax), so you don't have to.
Screenshots
System Requirements
Norton SystemWorks Premier
Windows® XP Home/XP Pro
* 300MHz or higher processor
* 256MB of RAM
* 400MB of available hard disk space
Required for all installations
* DVD or CD-ROM drive
* Microsoft® Internet Explorer 5.5 or higher (6.0 recommended)
* Super VGA (800x600) or higher-resolution video adapter and monitor
* Average of 10% of total hard disk space for Norton GoBack history (configurable)
Email scanning supported for standard POP3 and SMTPcompatible email clients
Supported instant messaging clients:
* AOL® Instant Messenger 4.7 or higher
* Yahoo!® Instant Messenger 5.x or 6.x
* MSN® Messenger 6.0 or higher
Supported file systems and devices
File systems supported for backup and recovery tasks:
* FAT16, FAT16X, FAT32, FAT32X
* NTFS
* Dynamic Disks
* Linux® EXT2/3 and Linux Swap Partitions
Hard drives and removable media supported:
* CDR/RW and DVD+-R/RW drives
* USB and FireWire® (IEEE 1394) devices
* Iomega® Zip® and Jaz® drives
