Big Digger Гуру
Google SketchUp Pro 6.0.515 - пакет для трехмерного моделирования.
Google SketchUp Pro v.6.0.515 - is powerful, intuitive 3D modeling software that allows designers and planners to explore, communicate and present complex design concepts. The simple, robust toolset and intelligent drawing system make it easy to create and modify models, while the import/export capability gives you the flexibility and functionality required in a professional workflow. And now, with SketchUp Pro’s LayOut feature, you can integrate 3D models with 2D elements like photographs, artwork, text, title blocks – even handwritten notes – to create compelling interactive presenta-tions. LayOut also enables you to output large-format, high-resolution documents. In a single program, SketchUp Pro 6 combines high-quality 2D design tools with the ability to manipulate dimensionally accurate 3D models with CAD-like precision and scale.
Who uses SketchUp?
Fans of SketchUp include everyone from industry giants to industry-giants-in-the-making. As the 'Switzerland' of design software, we're neutral with respect to file formats and work hard to get along with everybody. In keeping with this, we've designed SketchUp to be compatible with most other modeling, image editing, and illustration applications that designers use. From architects to movie and set designers, from game developers to graphic artists, our users rely on SketchUp to help make their design ideas come to life.
New Features: And now Google SketchUp Pro 6 lets you create 3D models from photographs, match existing models to background photos, render sketchy effects and fog and mark your models with 3D text, logos and watermarks. With the new Styles palette, you have easy access to a collection of display settings, which you can save and share. You also have greater control, with new features like enhanced modifier keys that let you perform operations like “copy” while you move, rotate or push/pull. If you use Google Earth, Google SketchUp allows you to place your models using real-world coordinates and share them with the world using the 3D Warehouse.
ftp://ftp.nsk.in/upload/SOFT/Google SketchUp Pro 6.0.515.zip |
dlnsk Гуру
и уважуха!
Я искал Pro вариант какое-то время назад... |
