Smart Projects IsoBuster Pro v2.2
Big Digger
СообщениеДобавлено: Вс 16-09-07 : 22-24    Заголовок сообщения: Smart Projects IsoBuster Pro v2.2 Ответить с цитатой
Smart Projects IsoBuster Pro v.2.2 от 20 августа 2007 г. предназна-чен для спасения и попытки восстановления данных с различного рода носителей CD-R/RW, DVD-R/RW/+R/+RW при не корректном завершении записи мулитисессионных или просто с повреждённых дисков. IsoBuster поддерживает следующие форматы дисков: ISO9660, Joliet, Romeo, Big Endian, Little Endian, UDF 2.01, UDF 1.02, UDF 1.5, поддерживаются также форматы образов диска: *.DAO (Duplicator), *.TAO (Duplicator), *.ISO (Nero, BlindRead, Creator), *.BIN (CDRWin), *.IMG (CloneCD), *.CIF (Creator), *.FCD (Uncompressed), *.NRG (Nero), *.GCD (Prassi), *.P01 (Toast), *.C2D (WinOnCD), *.CDI (DiscJuggler), *.CUE (CDRWin), *.CD (OptImage), *.GI (PrimoDVD), *.PXI (PlexTools).
IsoBuster Pro 2.2 (August 20, 2007) is a CD/DVD and (Disk) Image File data recovery tool, that can read and extract files, tracks and sessions from CD-i, VCD, SVCD, CD-ROM, CD-ROM XA, DVD, DVCD and others.
Whats new in IsoBuster Pro 2.2: - This version features BD and HD DVD, the two new blue laser formats.
Changes:
- Support for command line parameters.
- Support for mkisofs El Torito Patch (boot image).
- Support for spanned *.dmg image files. (*.dmg, *.002.dmgpart).
- Option to specify that extraction of image files is in *.ISO format, rather than *.TAO or *.BIN.
- Image file extraction save dialog, 'save as type' allows to select between *.ISO and *.TAO or *.BIN.
- Show file extents. (Show the different parts of a file, when it is fragmented on disc.).
- Ability to add/edit extents on custom created files (e.g. Lost and Found and Customizable file system).
- Ability to add a customizable file system (where you can add, edit files, for engineering purposes).
Improvements:
- Show [xx%] status in task bar at the bottom, during extraction.
- Improvements for UTF7 and UTF8 interpretation.
- More progress information is exposed when completing a managed image file. - Various smaller GUI improvements, e.g. icons.
- Various smaller improvements. - Turned off message asking to turn on admin rights on a system other than XP.
isobuster22pro.zip
 Описание:  Smart Projects IsoBuster Pro v2.2 + SERIAL
Скачать
 Размер файла:  2.81 MB
 Скачано:  103 раз(а)
