Не проходит авторизация.
PILOT
Матёрый
СообщениеДобавлено: Пт 10-10-08 : 21-47    Заголовок сообщения: Не проходит авторизация. Ответить с цитатой
Собственно, сабж.
Ежесуточное отключение PPPoE, давным-давно не было проблем. Сейчас:
Oct 10 21:36:19 pppd[2224]: No response to PAP authenticate-requests
Oct 10 21:36:19 cfgmgr(pppoe-114): PPPoE Exit Status = 19
Oct 10 21:36:19 cfgmgr(pppoe-114): PPPoE Send a Interface Delete Event Below
Oct 10 21:36:19 cfgmgr(pppoe-114): Authenication Failure with Peer
Oct 10 21:36:19 pppd[2224]: Connection terminated.
Oct 10 21:36:19 pppd[2224]: Doing disconnect
Oct 10 21:36:20 pppd[2495]: pppd 2.4.4 started by root, uid 0
Oct 10 21:37:12 cfgmgr(pppoe-114): New PPP_ID: 0x8424
Oct 10 21:37:12 cfgmgr(pppoe-114): Received pppoe server mac: 0x00-90-1a-42-be-61
Oct 10 21:37:12 pppd[2495]: Got connection: 8424
Oct 10 21:37:12 pppd[2495]: Saved Session ID: 0
Oct 10 21:37:12 pppd[2495]: AC MAC address: 00-90-1a-42-be-61
Oct 10 21:37:12 pppd[2495]: Connect: ppp0 {--} nas1
Oct 10 21:37:34 pppd[2495]: PAP authentication failed
Oct 10 21:37:34 cfgmgr(pppoe-114): PPPoE Exit Status = 19
Oct 10 21:37:34 cfgmgr(pppoe-114): PPPoE Send a Interface Delete Event Below
Oct 10 21:37:34 cfgmgr(pppoe-114): Authenication Failure with Peer
Oct 10 21:37:34 pppd[2495]: Connection terminated.
Oct 10 21:37:34 pppd[2495]: Doing disconnect
Oct 10 21:37:34 pppd[2531]: pppd 2.4.4 started by root, uid 0
Oct 10 21:38:32 cfgmgr(pppoe-114): New PPP_ID: 0x6428
Oct 10 21:38:32 cfgmgr(pppoe-114): Received pppoe server mac: 0x00-90-1a-42-be-61
Oct 10 21:38:32 pppd[2531]: Got connection: 6428
Oct 10 21:38:32 pppd[2531]: Saved Session ID: 0
Oct 10 21:38:32 pppd[2531]: AC MAC address: 00-90-1a-42-be-61
Oct 10 21:38:32 pppd[2531]: Connect: ppp0 {--} nas1
Oct 10 21:38:41 pppd[2531]: PAP authentication failed
Oct 10 21:38:41 cfgmgr(pppoe-114): PPPoE Exit Status = 16
Oct 10 21:38:41 cfgmgr(pppoe-114): PPPoE Send a Interface Delete Event Below
Oct 10 21:38:41 cfgmgr(pppoe-114): Terminated: Modem Hang-Up
Oct 10 21:38:41 cfgmgr(pppoe-114): Reverting Back PPPoE Session ID: 0x0
Oct 10 21:38:41 cfgmgr(pppoe-114): 15,16 exit report handling - sid set to 0 .
Oct 10 21:38:41 cfgmgr(pppoe-114): Connection Attempt Backoff (PPPoE) for 60 seconds.
Oct 10 21:38:41 pppd[2531]: Modem hangup
Oct 10 21:38:41 pppd[2531]: Connection terminated.
Oct 10 21:38:41 pppd[2531]: Doing disconnect
Модем пытается подключится каждую минуту, и ни фига.
Порт на DSLAM'е перезагрузил, картина прежняя.
Есть у кого еще похожие проблемы?
PILOT
Матёрый
СообщениеДобавлено: Пт 10-10-08 : 22-01    Заголовок сообщения: Ответить с цитатой
Х.з. что было, стоял тип авторизации AUTO, поставил CHAP, соединилось, правда не с первого раза. Можно тему в корзину или совсем удалить.
Aprelle
СообщениеДобавлено: Пт 10-10-08 : 22-15    Заголовок сообщения: Ответить с цитатой
где подобный лог модема глянуть можно?
СообщениеДобавлено: Пт 10-10-08 : 22-16    Заголовок сообщения: Ответить с цитатой
на акорпах: статус/лог
Aprelle
СообщениеДобавлено: Пт 10-10-08 : 22-40    Заголовок сообщения: Ответить с цитатой
Понятно, нашел лог в хуавее, несколько суток работал без переподключений, а сегодня часов в 18 скорость упала почти до нуля и ошибки CRC поперли большим потоком, переподключил модем -- снова все отлично, но в логах никаких варнингов нет ((
СообщениеДобавлено: Пт 10-10-08 : 22-45    Заголовок сообщения: Ответить с цитатой
совпадение. просто СТК гнал.
