Помогите настроить Cisco 877
nghst
СообщениеДобавлено: Сб 21-03-09 : 13-39    Заголовок сообщения: Помогите настроить Cisco 877 Ответить с цитатой
Здравствуйте. Никак не могу настроить Cisco 877.
Версия IOS:
Код:
router#show ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(6)T8, RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Jul-07 22:42 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
router uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:c870-advipservicesk9-mz.124-6.T8.bin"
Last reload reason: Reload Command
<skipped>
Cisco 877 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FHK1133133F
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Configuration register is 0x2102
Вот ее конфиг:
Код:
router#show run
Building configuration...
Current configuration : 3671 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
logging console critical
no aaa new-model
resource policy
clock timezone NSK 6
clock summer-time NSK recurring last Sun Mar 3:00 last Sun Oct 3:00
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-449235547
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-449235547
 revocation-check none
 rsakeypair TP-self-signed-449235547
crypto pki certificate chain TP-self-signed-449235547
 certificate self-signed 01
<Skipped>
  quit
username admin privilege 15 secret 5 <skipped>
interface ATM0
 no ip address
 no atm ilmi-keepalive
 dsl operating-mode auto
interface ATM0.1 point-to-point
 no snmp trap link-status
 pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
 ip address 192.168.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 ip tcp adjust-mss 1452
interface Dialer1
 ip address negotiated
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1390
 dialer pool 1
 no cdp enable
 ppp chap hostname nsk<skipped>
 ppp chap password 7 <skipped>
 ppp pap sent-username nsk<skipped> password 7 <skipped>
no ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
 login local
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
scheduler max-task-time 5000
webvpn context Default_context
 ssl authenticate verify all
 no inservice
end
Интерфейс ATM не поднимается:
Код:
router#show ip int br
Interface                   IP-Address      OK? Method   Status              Protocol
FastEthernet0              unassigned    YES unset        up                   down
FastEthernet1              unassigned    YES unset        up                   up
FastEthernet2              unassigned    YES unset        up                   down
FastEthernet3              unassigned    YES unset        up                   down
ATM0                          unassigned    YES NVRAM     initializing         down
ATM0.1                       unassigned    YES unset        initializing         down
Vlan1                         192.168.1.1    YES NVRAM     up                   up
NVI0                          unassigned     NO  unset        up                   up
Dialer1                       unassigned     YES NVRAM     up                   up
Результаты debug atm eve:
Код:
000025: *Mar  1 12:22:51.515 NSK: DSL(ATM0): 16: Modem state = 0x8
000026: *Mar  1 12:22:54.015 NSK: DSL(ATM0): 17: Modem state = 0x8
...<skipped>...
000039: *Mar  1 12:23:26.515 NSK: DSL(ATM0): 30: Modem state = 0x8
000040: *Mar  1 12:23:29.015 NSK: DSL(ATM0): Could not establish connection event=1
000041: *Mar  1 12:23:29.015 NSK: DSL: SM: [DMTDSL_DO_OPEN -> DMTDSL_INIT]
000042: *Mar  1 12:23:29.087 NSK: DSL: SM: [DMTDSL_INIT -> DMTDSL_DLOAD_1]
000043: *Mar  1 12:23:29.087 NSK: DSL: Downloading init_AMR-R-2.5.042_no_bist.bin
000044: *Mar  1 12:23:29.091 NSK: DSL:(ATM0) Downloaded 2 blocks... Finished!
000045: *Mar  1 12:23:29.091 NSK: DSL(ATM0): Sent command 0x14
000046: *Mar  1 12:23:31.091 NSK: DSL: Received response: 0x80
000047: *Mar  1 12:23:31.091 NSK: DSL: SM: [DMTDSL_DLOAD_1 -> DMTDSL_DLOAD_2]
000048: *Mar  1 12:23:31.091 NSK: DSL: Downloading AMR-R-2.5.042.bin
000049: *Mar  1 12:23:31.123 NSK: DSL(ATM0): Downloaded 100 blocks
000050: *Mar  1 12:23:31.155 NSK: DSL(ATM0): Downloaded 200 blocks
000051: *Mar  1 12:23:31.187 NSK: DSL(ATM0): Downloaded 300 blocks
000052: *Mar  1 12:23:31.219 NSK: DSL(ATM0): Downloaded 400 blocks
000053: *Mar  1 12:23:31.251 NSK: DSL(ATM0): Downloaded 500 blocks
000054: *Mar  1 12:23:31.283 NSK: DSL(ATM0): Downloaded 600 blocks
000055: *Mar  1 12:23:31.315 NSK: DSL(ATM0): Downloaded 700 blocks
000056: *Mar  1 12:23:31.347 NSK: DSL(ATM0): Downloaded 800 blocks
000057: *Mar  1 12:23:31.379 NSK: DSL(ATM0): Downloaded 900 blocks
000058: *Mar  1 12:23:31.415 NSK: DSL(ATM0): Downloaded 1000 blocks
000059: *Mar  1 12:23:31.447 NSK: DSL(ATM0): Downloaded 1100 blocks
000060: *Mar  1 12:23:31.479 NSK: DSL(ATM0): Downloaded 1200 blocks
000061: *Mar  1 12:23:31.511 NSK: DSL(ATM0): Downloaded 1300 blocks
000062: *Mar  1 12:23:31.543 NSK: DSL(ATM0): Downloaded 1400 blocks
000063: *Mar  1 12:23:31.575 NSK: DSL(ATM0): Downloaded 1500 blocks
000064: *Mar  1 12:23:31.615 NSK: DSL(ATM0): Downloaded 1600 blocks
000065: *Mar  1 12:23:31.647 NSK: DSL(ATM0): Downloaded 1700 blocks
000066: *Mar  1 12:23:31.679 NSK: DSL(ATM0): Downloaded 1800 blocks
000067: *Mar  1 12:23:31.711 NSK: DSL(ATM0): Downloaded 1900 blocks
000068: *Mar  1 12:23:31.743 NSK: DSL(ATM0): Downloaded 2000 blocks
000069: *Mar  1 12:23:31.775 NSK: DSL(ATM0): Downloaded 2100 blocks
000070: *Mar  1 12:23:31.811 NSK: DSL(ATM0): Downloaded 2200 blocks
000071: *Mar  1 12:23:31.843 NSK: DSL(ATM0): Downloaded 2300 blocks
000072: *Mar  1 12:23:31.875 NSK: DSL(ATM0): Downloaded 2400 blocks
000073: *Mar  1 12:23:31.907 NSK: DSL(ATM0): Downloaded 2500 blocks
000074: *Mar  1 12:23:31.939 NSK: DSL(ATM0): Downloaded 2600 blocks
000075: *Mar  1 12:23:31.971 NSK: DSL(ATM0): Downloaded 2700 blocks
000076: *Mar  1 12:23:32.003 NSK: DSL(ATM0): Downloaded 2800 blocks
000077: *Mar  1 12:23:32.035 NSK: DSL(ATM0): Downloaded 2900 blocks
000078: *Mar  1 12:23:32.067 NSK: DSL(ATM0): Downloaded 3000 blocks
000079: *Mar  1 12:23:32.099 NSK: DSL(ATM0): Downloaded 3100 blocks
000080: *Mar  1 12:23:32.131 NSK: DSL(ATM0): Downloaded 3200 blocks
000081: *Mar  1 12:23:32.163 NSK: DSL(ATM0): Downloaded 3300 blocks
000082: *Mar  1 12:23:32.195 NSK: DSL(ATM0): Downloaded 3400 blocks
000083: *Mar  1 12:23:32.231 NSK: DSL(ATM0): Downloaded 3500 blocks
000084: *Mar  1 12:23:32.263 NSK: DSL(ATM0): Downloaded 3600 blocks
000085: *Mar  1 12:23:32.295 NSK: DSL(ATM0): Downloaded 3700 blocks
000086: *Mar  1 12:23:32.327 NSK: DSL(ATM0): Downloaded 3800 blocks
000087: *Mar  1 12:23:32.335 NSK: DSL:(ATM0) Downloaded 3824 blocks... Finished!
000088: *Mar  1 12:23:32.335 NSK: DSL(ATM0): Sent command 0x14
000089: *Mar  1 12:23:34.335 NSK: set tx_gain_offset to 0
000090: *Mar  1 12:23:34.335 NSK: set rx_gain_offset to 0
000091: *Mar  1 12:23:34.335 NSK: set target_noise_margin_offset to 0
000092: *Mar  1 12:23:34.335 NSK: set max_bits_tone_limit to 15
000093: *Mar  1 12:23:34.335 NSK: changed current state to do open!!
000094: *Mar  1 12:23:34.335 NSK: DSL: SM: [DMTDSL_DLOAD_2 -> DMTDSL_DO_OPEN]
000095: *Mar  1 12:23:34.335 NSK: DSL: Send ADSL_OPEN command.
000096: *Mar  1 12:23:34.335 NSK: DSL(ATM0): Using subfunction 0x0
000097: *Mar  1 12:23:34.335 NSK: LOCAL:Max noise margin for power cutoff 31
000098: *Mar  1 12:23:34.335 NSK: DSL(ATM0): Sent extended command 0x3
000099: *Mar  1 12:23:36.835 NSK: DSL(ATM0): 1: Modem state = 0x8
000100: *Mar  1 12:23:39.335 NSK: DSL(ATM0): 2: Modem state = 0x8
С проводом все нормально - Huawai MT880u работает.
На циске лампочка CD постояно мигает.
В чем может быть косяк?
