Качество телефонной линии?
Ответить на тему    Форум АДСЛ КлубаМОДЕМЫ, ПРОШИВКИ, ИНСТРУКЦИИACORP
webset
СообщениеДобавлено: Ср 7-10-09 : 16-27    Заголовок сообщения: Качество телефонной линии? Ответить с цитатой
Скажите пожалуйста как мои параметры телефонной линии.?
Вот что показывает модем Acorp Sprinter@ADSL USB
10/05/2009 - 10:45:28 - EVENT = Ndis driver version: 13032.099.074.000
10/05/2009 - 10:45:28 - EVENT = Current MAC address: 00-14-2B-06-81-F2
10/05/2009 - 10:45:28 - EVENT = EEprom MAC address: 00-14-2B-06-81-F2
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Vendor: Conexant Systems Inc.
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Version: 3
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Firmware Version: 3.25.0
10/05/2009 - 10:45:28 - EVENT = Remote Data Pump Vendor: Unknown Vendor
10/05/2009 - 10:45:28 - EVENT = Remote Data Pump Firmware Version: 0
10/05/2009 - 10:45:28 - EVENT = ************* Start Statistics Acquisition *************
10/05/2009 - 10:45:28 - EVENT = CALL STATUS - Connected
09/30/2009 - 12:40:20 - EVENT = PHYSICAL STATISTICS -
Upstream Output Power = -38 dBm
Upstream Noise Margin = +2.3 dB
Upstream Attenuation = 3.3 dB
Upstream Bits per Frame = 229
Upstream CRC Errors = 1
Upstream FEC Errors = 1
Upstream HEC Errors = 0
Downstream Noise Margin = +10.0 dB
Downstream Attenuation = 3.3 dB
Downstream Bits per Frame = 1110
Downstream CRC Errors = 0
Downstream FEC Errors = 3
Downstream HEC Errors = 0
Startup Attempts = 1
Вот в другой день
10/05/2009 - 19:30:08 - EVENT = PHYSICAL STATISTICS -
Upstream Noise Margin = +2.0 dB
Upstream Attenuation = 3.5 dB
Upstream Bits per Frame = 140
Upstream CRC Errors = 0
Upstream FEC Errors = 19
Downstream Noise Margin = +2.9 dB
Downstream Attenuation = 3.5 dB
Downstream Bits per Frame = 732
Startup Attempts = 7
Вот в другой день
10/07/2009 - 10:42:03 - EVENT = PHYSICAL STATISTICS -
Upstream Bits per Frame = 225
Upstream CRC Errors = 2
Upstream FEC Errors = 0
Downstream Noise Margin = +9.3 dB
Downstream Bits per Frame = 1933
Downstream FEC Errors = 0
Скорость на порту стоит 2Мб.
Больше 2 Мб линия недержит.
rendy
СообщениеДобавлено: Чт 8-10-09 : 10-51    Заголовок сообщения: Ответить с цитатой
webset
Возьми нормальный adsl2+ Ethernet-модем и посмотри параметры с ним. Скорее всего, проблема в модеме.
webset
СообщениеДобавлено: Чт 8-10-09 : 12-18    Заголовок сообщения: Ответить с цитатой
rendy писал(а):
webset
Спасибо за ответ.
Пока возможности такой нет, как появятся обязательно это сделаю.
Ответить на тему    Форум АДСЛ КлубаМОДЕМЫ, ПРОШИВКИ, ИНСТРУКЦИИACORP Часовой пояс: GMT + 7
