Unexpected packet
youdjcommon
СообщениеДобавлено: Ср 20-01-10 : 17-44    Заголовок сообщения: Unexpected packet Ответить с цитатой
Здравствуйте!
такая ситуация:
Модем: LinkSys WAG325N
тариф: Webstream Трасса 2048 (физ. лица)
=периодические обрывы соединения=
лог устройства:
Wed, 2010-01-20 14:42:14 - Interface "nas0" created sucessfully
Wed, 2010-01-20 14:42:14 - Communicating over ATM 0.0.35, encapsulation: LLC
Wed, 2010-01-20 14:42:15 - Initialize LCP.
Wed, 2010-01-20 14:42:15 - Plugin pppoe loaded.
Wed, 2010-01-20 14:42:15 - PPPoE Plugin Initialized
Wed, 2010-01-20 14:42:15 - Plugin pppoe called.
Wed, 2010-01-20 14:42:15 - pppd 2.4.1 started by root, uid 0
Wed, 2010-01-20 14:42:15 - setting line discipline hook
Wed, 2010-01-20 14:42:15 - Sending PADI
Wed, 2010-01-20 14:42:15 - HOST_UNIQ successful match
Wed, 2010-01-20 14:42:15 - Unexpected packet: Ether addr: 00:90:1a:a1:ea:8f (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002d (PADO) PPPoE tag: type=0102 length=0009 (AC Name) data (UTF-8): NSK-BBAR2 PPPoE tag: type=0103 length=0004 (Host Uniq) dat
Wed, 2010-01-20 14:42:15 - Got connection: 26bf
Wed, 2010-01-20 14:42:15 - Connecting PPPoE socket: 00:90:1a:a1:ea:90 26bf nas0 0x1004e180
Wed, 2010-01-20 14:42:15 - using channel 5
Wed, 2010-01-20 14:42:15 - Using interface ppp0
Wed, 2010-01-20 14:42:15 - Connect: ppp0 <--> nas0
Wed, 2010-01-20 14:42:15 - Couldn't increase MTU to 1500.
Wed, 2010-01-20 14:42:15 - Couldn't increase MRU to 1500
Wed, 2010-01-20 14:42:15 - LCP is allowed to come up.
Wed, 2010-01-20 14:42:15 - Remote message: duplicate address detected
Wed, 2010-01-20 14:42:15 - PAP authentication failed
Wed, 2010-01-20 14:42:15 - LCP down.
Wed, 2010-01-20 14:42:15 - Connection terminated.
Wed, 2010-01-20 14:42:15 - Doing disconnect
Wed, 2010-01-20 14:42:15 - Exit.
Wed, 2010-01-20 14:43:16 - Interface "nas0" created sucessfully
Wed, 2010-01-20 14:43:16 - Communicating over ATM 0.0.35, encapsulation: LLC
Wed, 2010-01-20 14:43:17 - Initialize LCP.
Wed, 2010-01-20 14:43:17 - Plugin pppoe loaded.
Wed, 2010-01-20 14:43:17 - PPPoE Plugin Initialized
Wed, 2010-01-20 14:43:17 - Plugin pppoe called.
Wed, 2010-01-20 14:43:17 - pppd 2.4.1 started by root, uid 0
Wed, 2010-01-20 14:43:17 - setting line discipline hook
Wed, 2010-01-20 14:43:17 - Sending PADI
Wed, 2010-01-20 14:43:17 - HOST_UNIQ successful match
Wed, 2010-01-20 14:43:17 - Unexpected packet: Ether addr: 00:90:1a:a1:ea:90 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002d (PADO) PPPoE tag: type=0102 length=0009 (AC Name) data (UTF-8): NSK-BBAR2 PPPoE tag: type=0103 length=0004 (Host Uniq) dat
Wed, 2010-01-20 14:43:17 - Got connection: 2728
Wed, 2010-01-20 14:43:17 - Connecting PPPoE socket: 00:90:1a:a1:ea:8f 2728 nas0 0x1004e180
Wed, 2010-01-20 14:43:17 - using channel 6
Wed, 2010-01-20 14:43:17 - Using interface ppp0
Wed, 2010-01-20 14:43:17 - Connect: ppp0 <--> nas0
Wed, 2010-01-20 14:43:17 - Couldn't increase MTU to 1500.
Wed, 2010-01-20 14:43:17 - Couldn't increase MRU to 1500
Wed, 2010-01-20 14:43:17 - LCP is allowed to come up.
Wed, 2010-01-20 14:43:18 - Remote message: duplicate address detected
Wed, 2010-01-20 14:43:18 - PAP authentication failed
Wed, 2010-01-20 14:43:18 - Couldn't increase MTU to 1500.
Wed, 2010-01-20 14:43:18 - Couldn't increase MRU to 1500
Wed, 2010-01-20 14:43:18 - LCP down.
Wed, 2010-01-20 14:43:18 - Connection terminated.
Wed, 2010-01-20 14:43:18 - Doing disconnect
Wed, 2010-01-20 14:43:18 - Exit.
Wed, 2010-01-20 14:44:17 - Interface "nas0" created sucessfully
Wed, 2010-01-20 14:44:17 - Communicating over ATM 0.0.35, encapsulation: LLC
Wed, 2010-01-20 14:44:17 - Initialize LCP.
Wed, 2010-01-20 14:44:17 - Plugin pppoe loaded.
Wed, 2010-01-20 14:44:17 - PPPoE Plugin Initialized
Wed, 2010-01-20 14:44:17 - Plugin pppoe called.
Wed, 2010-01-20 14:44:17 - pppd 2.4.1 started by root, uid 0
Wed, 2010-01-20 14:44:17 - setting line discipline hook
Wed, 2010-01-20 14:44:17 - Sending PADI
Wed, 2010-01-20 14:44:17 - HOST_UNIQ successful match
Wed, 2010-01-20 14:44:17 - Unexpected packet: Ether addr: 00:90:1a:a1:ea:90 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002d (PADO) PPPoE tag: type=0102 length=0009 (AC Name) data (UTF-8): NSK-BBAR2 PPPoE tag: type=0103 length=0004 (Host Uniq) dat
Wed, 2010-01-20 14:44:17 - Got connection: 2786
Wed, 2010-01-20 14:44:17 - Connecting PPPoE socket: 00:90:1a:a1:ea:8f 2786 nas0 0x1004e180
Wed, 2010-01-20 14:44:17 - using channel 7
Wed, 2010-01-20 14:44:17 - Using interface ppp0
Wed, 2010-01-20 14:44:17 - Connect: ppp0 <--> nas0
Wed, 2010-01-20 14:44:17 - Couldn't increase MTU to 1500.
Wed, 2010-01-20 14:44:17 - Couldn't increase MRU to 1500
Wed, 2010-01-20 14:44:17 - LCP is allowed to come up.
Wed, 2010-01-20 14:44:18 - PAP authentication success
Wed, 2010-01-20 14:44:18 - local IP address 92.127.189.246
Wed, 2010-01-20 14:44:18 - remote IP address 213.228.116.8
Wed, 2010-01-20 14:44:18 - primary DNS address 217.70.106.5
Wed, 2010-01-20 14:44:18 - secondary DNS address 217.70.96.34
Wed, 2010-01-20 15:09:14 - ath0: WPA rekeying GTK
Wed, 2010-01-20 16:09:14 - ath0: WPA rekeying GTK
вот такие срывы бывают очень часто, буду признателен за любой ответ.
спасибо
с Ув.
rendy
СообщениеДобавлено: Ср 20-01-10 : 17-49    Заголовок сообщения: Ответить с цитатой
youdjcommon
До записи по логу в Wed, 2010-01-20 14:42:14 был физический обрыв линка?
youdjcommon
СообщениеДобавлено: Ср 20-01-10 : 17-53    Заголовок сообщения: Ответить с цитатой
rendy писал(а):
youdjcommon
физического обрыва я несовершал , на модеме гаснет индикатор "internet" и он запускает видимо процедуру переподключения
прошу прощения забыл хвостики
Wed, 2010-01-20 14:41:43 - Adsl is disconnected
Wed, 2010-01-20 14:41:44 - Terminating on signal 15.
Wed, 2010-01-20 14:41:44 - Couldn't increase MTU to 1500.
Wed, 2010-01-20 14:41:44 - Couldn't increase MRU to 1500
Wed, 2010-01-20 14:41:44 - LCP down.
Wed, 2010-01-20 14:41:44 - Modem hangup
Wed, 2010-01-20 14:41:44 - Connection terminated.
Wed, 2010-01-20 14:41:44 - Connect time 206.5 minutes.
Wed, 2010-01-20 14:41:44 - Sent 254442229 bytes, received 15545155 bytes.
Wed, 2010-01-20 14:41:44 - Doing disconnect
Wed, 2010-01-20 14:41:44 - sendto returned:
Wed, 2010-01-20 14:41:44 - Exit.
и потом весть лог ,который в первом посте
спасибо.
rendy
СообщениеДобавлено: Ср 20-01-10 : 18-09    Заголовок сообщения: Ответить с цитатой
youdjcommon
Физический обрыв линка. Далее линк восстанавливается и сессия продолжает весеть какое-то время, около 2-3 минут (это нормально приеё некорректном завершении), отсюда какое-то время нет авторизации и наблюдаются подобные записи в логе. Физические обрывы - это ненормально, их не должно быть вообще.
Прошивку с официального сайта производителя обновляли? Если нет, скачайте и выполните обновление (по LAN-кабелю, через IE с полным сбросом настроек модема до и после).
Параметры линии покажите (если не знаете, что это такое, воспользуйтесь поиском по форуму и приведите полные параметры линии из админки модема по аналогии с другими модемами).
youdjcommon
СообщениеДобавлено: Ср 20-01-10 : 18-47    Заголовок сообщения: Ответить с цитатой
Благодарю Вас Rendy за ответы
прошивку я ему менял примерно полгода назад, посмотрю у производителя может новая вышла, Ок.
к сожалениюв данном модеме по поводу статистики всё очень скудно
вот что удалось посмотреть:
из модема:
Firmware Version: V1.00.12
Login Type: RFC 2516 PPPoE
Interface: Up
Status: Up
DSL Modulation: Multimode
Downstream Rate: 4941 Kbps
Upstream Rate: 939 Kbps
Encapsulation: RFC 2516 PPPoE
Multiplexing: LLC
QoS: UBR
PCR Rate:
SCR Rate:
Autodetect: Enable
VPI: 0
VCI: 35
Enable: 1
PVC Status: Up
с сайта поддержки:
Стандарт модуляции текущего соединения g992-5-a
Входящий поток
Текущая скорость подключения 4941 Kbps
Глубина интерливинга 1.1 ms
Соотношение сигнал-шум 11.7 dB Линия хорошая.
Затухание сигнала 48.9 dB
Выходная мощность сигнала 19.4 dBm
Исходящий поток
Текущая скорость подключения 939 Kbps
Глубина интерливинга 1.5 ms
Соотношение сигнал-шум 11.9 dB Линия хорошая.
Затухание сигнала 27.9 dB Линия хорошая.
Выходная мощность сигнала 12.2 dBm
спасибо
с Уважением
rendy
СообщениеДобавлено: Ср 20-01-10 : 19-04    Заголовок сообщения: Ответить с цитатой
youdjcommon
По показаниям help.es-nso.ru линия плохая, профайл на DSLAM неоптимальный.
В каком состоянии линия от модема до щитка? Скрутки, дополнительные устройства имеются?
Девайс на BCM6358,
параметры линии на модеме можно попробовать посмотреть через подключение к модему с помощью telnet:
adslctl info --stats
или adsl info --stats
youdjcommon
СообщениеДобавлено: Ср 20-01-10 : 19-16    Заголовок сообщения: Ответить с цитатой
да и так уже от скудности web интерфейса полез в Telnet
, тока в "семёрке" самого телнета нету , да и еще выяснилось что данная модель не работает по телнетуАп стену друже!
а подозрения по поводу качества здешей линии у меня давно закрались))
дом очень старый..
до так называемого щитка обычная "лапша" метров 20,
на линии :
база от радиотелефона SIEMENS Gigaset SL375 через сплиттер ZYXEL AS 6 EE
скруток нет
пойду в подъез провода смотреть
спасибо
с Ув.
rendy
СообщениеДобавлено: Ср 20-01-10 : 19-53    Заголовок сообщения: Ответить с цитатой
youdjcommon
Ну статистику теперь знаете, где можно попытаться посмотреть. Проводку лучше заменить на витую пару, на участке от сплиттера до щитка не должно быть посторонних устройств.
Также, можно попытаться сделать бэкап конфига модема, затем открыть обычным блокнотом, в явном виде найти опцию PhyR, и изменить значение для её включения. Там же можно включить bitswap, SRA, i24k и Annex M (если есть необходимость и опции недоступны для включения в админке модема). Затем сохранить конфиг и залить обратно в модем. Если профиль на DSLAM не будет поддерживать какую-либо из опций, то хуже не будет, просто они не будут работать.
youdjcommon
СообщениеДобавлено: Ср 20-01-10 : 20-01    Заголовок сообщения: Ответить с цитатой
Благодарю Rendy за ценную информацию!
буду заниматься модемом и попробую Интеркосс воткнуть вместо этого и проверю сигналы,
и витую пару брошу.
результаты отпишу сюда.
еще раз большое спасибо
С Уважением.
youdjcommon
СообщениеДобавлено: Чт 21-01-10 : 18-31    Заголовок сообщения: Ответить с цитатой
В общем сделал я бекапный файл с Linsys , честно говоря очень разочаровало его наполнение и "выполнение", все параметры в одну строку, ни разделов , ни переносов - просто куча, да и незная "алфавита" данного устройства многие команды остаются для меня непонятными Ап стену друже! ненашёл я тех комманд которые предлагались к изменению
конфиг wag325n:
time_zone=GMT+6 1 time_daylight=0 restore_default=0 wan_ifname=ppp0 wan_mode=pppoe
wan_iptype=Dynamic wan_ipaddr= wan_netmask= wan_gateway= wan_mtu=1500 wan_fix_dns=0
wan_dns1= wan_dns2= wan_macaddr= wan_encap=0 pppoa_encap=1 wan_vpivci_detect=1
wan_vpi=0 wan_vci=35 wan_dsl_mod=a wan_account= wan_domain= wan_dod=0 wan_qos=ubr
wan_pcr= wan_scr= wan_cmtu=auto dhcp_dns0=217.70.106.5 dhcp_dns1=217.70.96.34
dhcp_dns2= dhcp_wins= lan_if=br0 lan_ipaddr=192.168.1.1 lan_netmask=255.255.255.0
lan_bipaddr=192.168.1.255 dhcp_server_enable=1 dhcp_server_ip= dhcp_start_ip=192.168.1.100
dhcp_end_ip=192.168.1.149 dhcp_reserved= dhcp_lease=0 http_username=***********
 http_password=************ h
ttp_timeout=5 rt_static_route= rt_rip_version=1 rt_rip_direction=0 ddns_enable=0
ddns_service_provider= ddns_user_name= ddns_password= ddns_host_name= ddns_use_wildcards=0
pppoe_username=*********** pppoe_password=****** pppoe_idle=5 pppoe_service=
pppoe_redial=30 pppoa_username= pppoa_password= pppoa_ipaddr= mail_enable=0 mail_logfull=0
mail_sendlog=2 mail_server= mail_recipient= mail_dos=1 mail_portscan=1 mail_block=1
mail_sh_day=0 mail_sh_hour=1 log_dos=1 log_block=1 log_login=1 log_gateway=1 log_type=0
log_remote_ip= fw_nat=1 fw_block=1 fw_access_policy= fw_block_trust_enable=0
fw_block_trust= fw_services_def=Any(ALL):any:1-65535Any(TCP):tcp:1-65535
Any(UDP):udp:1-65535AIM:tcp:5190-5190BGP:tcp:179-179BOOTP_CLIENT:udp:68-68
BOOTP_SERVER:udp:67-67CU-SEEME:both:7648-24032DNS:both:53-53FINGER:tcp:79-79
FTP:tcp:20-21H.323:tcp:1720-1720HTTP:tcp:80-80HTTPS:tcp:443-443IDENT:tcp:113-113I
KE:udp:500-500IMAP:tcp:143-143IRC:both:6667-6667NEWS:tcp:144-144NFS:udp:2049-2049
NNTP:tcp:119-119PING:icmp:0-0POP3:tcp:110-110RCMD:tcp:512-512REAL-AUDIO:tcp:7070-7070
REXEC:tcp:514-514RLOGIN:tcp:513-513RTELNET:tcp:107-107RTSP:both:554-554SFTP:tcp:115-115
SMTP:tcp:25-25SNMP:both:161-161SNMP-TRAPS:both:162-162SQL-NET:tcp:1521-1521
SSH:both:22-22STRMWORKS:udp:1558-1558TACACS:udp:49-49TELNET:tcp:23-23TFTP:udp:69-69
VDOLIVE:tcp:7000-7000VPN-IPSEC:udp:500-500VPN-L2TP:udp:1701-1701VPN-PPTP:tcp:1723-1723
fw_services= fw_in_rules=s:1:0:HTTP:101:0:80:80s:2:1:FTP:101:0:21:21s:3:0:rdp:101:0:3389:3389
s:4:1:Telnet:100:0:23:23s:5:0:SMTP:0:0:25:25s:6:0:TFTP:0:1:69:69s:7:1:Acid:103:0:****:****
s:8:1:dc1:103:0:1236:1236s:9:1:dc2:103:1:1237:1237s:10:0:emule1:101:0:50836:50836
s:11:0:emule2:101:1:34641:34641s:12:1:fly:101:1:1235:1235s:13:1:flly:101:0:1234:1234
s:14:1:ra2:101:0:****:****s:15:1:ra:100:0:4899:4899 fw_out_rules= fw_dmz_enable=0
fw_dmz= fw_spi=1 fw_response_ping=1 fw_schedule=1111111:00:00-24:00 fw_time_zone=GMTb
fw_remote=1 fw_remote_type= fw_remote_range_start= fw_remote_range_end= fw_remote_single=
fw_remote_port=8080 ntp_custom=0 ntp_server= upnp_enable=1 upnp_adv_time=30 upnp_ttl=4
snmp_enable=0 snmp_read_community= snmp_set_community= snmp_sys_name= snmp_sys_contact=
snmp_sys_location= snmp_trap_to= dhcpc_enable=1 ipsec_passthrough_enable=1
pptp_passthrough_enable=1 l2tp_passthrough_enable=1 ping_size=60 ping_number=1
ping_interval=1000 ping_timeout=5000 wl_ifname= wl_hwaddr= wl_phytype=g
wl_corerev= wl_phytypes= wl_radioids= wl_ssid=linksys wl_country= wl_country_code=
wl_radio=1 wl_closed=0 wl_ap_isolate=0 wl_mode=ap wl_lazywds=0 wl_wds= wl_wds_timeout=1
wl_wep=disabled wl_auth=0 wl_key=1 wl_key1= wl_key2= wl_key3= wl_key4= wl_maclist=
wl_macmode=disabled wl_channel=11 wl_reg_mode=off wl_dfs_preism=60 wl_dfs_postism=60
wl_rate=0 wl_mrate=0 wl_rateset=default wl_frag=2346 wl_rts=2346 wl_dtim=1 wl_bcn=100
wl_plcphdr=long wl_gmode=1 wl_gmode_protection=auto wl_afterburner=off wl_frameburst=off
wl_wme=off wl_antdiv=-1 wl_infra=1 wl_auth_mode=none wl_wpa_psk= wl_wpa_gtk_rekey=3600
wl_radius_ipaddr= wl_radius_key= wl_radius_port=1812 wl_crypto=tkip wl_net_reauth=3600
wl_akm= wl_wme_sta_bk=151023700off wl_wme_sta_be=151023300off
wl_wme_sta_vi=715260163008off wl_wme_sta_vo=37232641504off
wl_wme_ap_bk=151023700off wl_wme_ap_be=1563300off
wl_wme_ap_vi=715160163008off wl_wme_ap_vo=37132641504off wl_wme_no_ack=off
wl_maxassoc=128 wl_unit=0 wl_radius_life=3600 wl_radius2_life=3600 wl_radius2_port=1812
wl_radius3_port=1812 wifi_80211_gonly=0 wifi_ssid=Belyi wifi_power=0 wifi_region=USA
wifi_channel=11 wifi_auth_type=4 wifi_security=psk wifi_key_len=0 wifi_def_key=1
wifi_key1=********** wifi_key2=********** wifi_key3=********** wifi_key4=**********
wifi_access_control=disabled wifi_access_list= wifi_if_on=1 wifi_broadcast_ssid=enable
wifi_wep_on=0 wifi_dot11_iso=1 wifi_radius_port=1812 wifi_psk_pwd=*******************
wifi_beacon=100 wifi_auth=auto wifi_rate=0 wifi_nrate=16 wifi_dtim=1
wifi_afterburner=off wifi_frag=2346 wifi_rts=2346 wifi_rateset=default wifi_gprot=off
wifi_sort=mac wifi_wchannel=9 wifi_cwm_mode=1 wifi_wmm=1 wifi_ackmode=1
wifi_wpapsk_enc=tkip+aes wifi_wpa2psk_enc=tkip+aes wifi_wpa3psk_enc=TKIP+AES
wifi_wpa4psk_enc=TKIP+AES wifi_wsc_internalreg=1 wifi_wsc_iechange=0
wifi_wsc_configured=0 mail_enable=0 mail_logfull=0 mail_sendlog=2 mail_server=
mail_recipient= mail_dos=1 mail_portscan=1 mail_block=1 mail_sh_day=0
log_remote_ip= fw_protection=1 fw_filter_proxy=0 fw_filter_cookies=0
fw_filter_java=0 fw_filter_activex=0 fw_block_wanrequest=0 log_enable=1
email_alert=0 dos_thresholds=20 smtp_mail_server= email_alert_addr=
email_return_addr= qos_ds=disable qos_dslist=FTP:HHTTP:HTELNET:H
SMTP:HPOP3:H0:L0:L0:L device_name=WAG325N lan_ifnames=br0 wl0
language=1 igmp_proxy=0 wizard_enable=1 wlan_mgr_enable=1 wl0_ssid=linksys
wl0_closed=0 wl0_wpa_psk= wl0_auth=auto wl0_wep=disabled wl0_auth_mode=none
wl0_crypto=tkip wl0_akm= wlledgpio=1 wl0gpio0=0 wl0gpio1=0 wl0gpio2=0 wl0gpio6=2
wifi_dot11_mode=bg wl_ackmod=0 wl_QoS=enable h_bw_type=auto bpa_username=
bpa_password= bpa_dod=0 bpa_idle=5 bpa_redial=30 bpas_ipaddr= ip_mode=v4
ip6_method=tun ip6_prefix=2002:c0a8:101: ip6_postfix=:1 ip6_prelen=48
ip6_addr_method=stateless dhcp6_preftime=86400 dhcp6_validtime=86400
dhcp6_start=:2 dhcp6_end=:100 ip6_dns1= ip6_dns2= codepage=windows-1252
upnp_uuid_lan=70d3ccc6-1dd2-11b2-87d0-001d7eb231f3
upnp_uuid_wancd=70d49016-1dd2-11b2-8a5d-001d7eb231f5
upnp_uuid_wand=70d49017-1dd2-11b2-8a5d-001d7eb231f5
upnp_uuid_igd=70d49016-1dd2-11b2-8a5e-001d7eb231f5
wl_radius_ip= wl_radius_psk=
воткнул вместо него Интеркросс 5633e который
статистика такая:
Statistics -- ADSL
This page shows the current ADSL statistics.
Mode : ADSL2
Latency : Interleave
Trellis Coding : Enable
Status : SHOWTIME.L0
Power Level : L0
Downstream Uptream
SNR Margin (dB) : 11.8 12.9
Attenuation (dB) : 47.5 30.0
Power (dBm) : 19.5 13.0
Attainable Rate (Kbps) : 5844 928
Rate (Kbps) : 5065 928
K (number of bytes in DMT frame) : 39 14
R (number of check bytes in RS code : 10 10
S (RS code word size in DMT frame) : 0.98 7.64
D (interleaver depth) : 64 8
Delay (msec) : 15.71 15.28
FEC : 9881 0
CRC : 67 0
Total ES : 28 602
Total SES : 0 36
Total UAS : 0 46494
Itf Rx_pkt Rx_err Rx_drop Tx_pkt Tx_err Tx_drop
eth0 89697 0 0 70270 0 0
0/35 57624 7 7 79041 0 0
Memory Usage:
Total: 5668 kB Free: 212 kB
Alias Name ADSL Modem/Router
Software Version 1.3.9
DSP Version 2.8.1.6
DSL
DSL mode ADSL2 ADSL2+
DSL Status ADSL2, SHOWTIME.L0
Upstream Speed 928 kbps (Interleave)
Downstream Speed 5065 kbps (Interleave)
Upstream SNR 12.9dB
Downstream SNR 12.7dB
Reconnection Counts 0
Uptime 2:02
Showtime 2h:01m
help.es-nso.ru
Параметр Значение Комментарий
Стандарт модуляции текущего соединения g992-3-a
Входящий поток
Текущая скорость подключения 5065 Kbps
Глубина интерливинга 1.8 ms
Затухание сигнала 47.1 dB
Выходная мощность сигнала 19.3 dBm
Исходящий поток
Текущая скорость подключения 928 Kbps
Соотношение сигнал-шум 12.8 dB Линия хорошая.
Затухание сигнала 26.8 dB Линия хорошая.
витой пары пока нету,
а вот в подъезде посмотрел - там висит под потолком такая колодка к ней толстый кабель приходит с улицы и далее по квартирам через ботовые соединители.
скрутки там еще те! Shocked
проверил соединения там ,почистил , протянул болтики и произвел всю статистику ,что выше.
понаблюдаю пару дней как будет жить Интеркросс
спасибо
с Ув.
rendy
СообщениеДобавлено: Пт 22-01-10 : 12-18    Заголовок сообщения: Ответить с цитатой
youdjcommon
По поводу команд - значит, для этой модели их просто нет.
По поводу статистики - параметры не улучшились, тяните витую пару, проверяйте наличие посторонних устройств, правильность подключения и влияние отключения телефона на изменение параметров (если модем напрямую подключить к линии без сплиттера).
youdjcommon
СообщениеДобавлено: Ср 3-02-10 : 20-06    Заголовок сообщения: Ответить с цитатой
в общем вся пляска с тазами Прошу Вас!!! и бубнами dance oop не помогла....
подытоживаю:
- использовались три разных ADLS модема (LinkSys WAG325N, Интеркросс 5633e, D-Link DSL524-T) все с последними прошивками
- прозвонка кабеля от модема до колодки в подъезде
- замена "лапши" на витую пару
спрашивал у телефонистов - говорят что протяженность плеча до АТС видимо великовата,
да и еще за окном настоящая железная дорога ,блин Ап стену друже!
так,что вот пока как то так))
последние результаты из help.es-nso.ru
Стандарт модуляции текущего соединения 00:00:00:00:00:00:00:04:00:00:00:00:00:00:00:00
Входящий поток
Текущая скорость подключения 3210 Kbps
Глубина интерливинга 1.7 ms
Соотношение сигнал-шум 13 dB Линия хорошая.
Затухание сигнала 48.2 dB
Выходная мощность сигнала 17.3 dBm
Исходящий поток
Текущая скорость подключения 1021 Kbps
Глубина интерливинга 1.4 ms
Соотношение сигнал-шум 24.4 dB Линия хорошая.
Затухание сигнала 32.8 dB Линия плохая.
Выходная мощность сигнала 12.7 dBm
если у кого есть какие соображения - буду рад
всем спасибо
с Уважением.
