очень долго не подключается модем
Evgenius
СообщениеДобавлено: Пн 1-02-10 : 23-21    Заголовок сообщения: очень долго не подключается модем Ответить с цитатой
сабж,после перезагрузки модема линк не начинает моргать,минут 10 проходит,смотрю горит!и скорость какая маленькая...
Modem Status
Connection Status Connected
Us Rate (Kbps) 639
Ds Rate (Kbps) 3046
US Margin 14
DS Margin 11
Trained Modulation ADSL_2plus
LOS Errors 0
DS Line Attenuation 26
US Line Attenuation 14
Peak Cell Rate 1507 cells per sec
CRC Rx Fast 10
CRC Tx Fast 0
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
и лог если это то
Jan 1 12:00:11 cfgmgr(sar): Could not get oam_ping_interval from boot loader env
Jan 1 12:00:11 cfgmgr(sar): Trying to retreive the value from Configuration
Jan 1 12:00:11 cfgmgr(sar): oamPingInterval(20)(20)
Jan 1 12:00:11 cfgmgr(ap): AP Acquiring Lock
Jan 1 12:00:11 cfgmgr(pppoe-107): Valid Configuration Tree
Jan 1 12:00:11 cfgmgr(resolver): stat successfull for /etc/resolv.conf.
Jan 1 12:00:11 cfgmgr(resolver): Resolver Polling Timer Started succesfully.
Jan 1 12:00:11 cfgmgr(sar): DSL Polling Timer Started succesfully.
Jan 1 12:00:12 cfgmgr(fdb): Firewall NAT service started
Jan 1 12:00:12 cfgmgr(ap): AP REPORT LOCK ACQUIRED
Jan 1 12:00:12 cfgmgr(ap): wlan_handle_load_event - Acquired Lock
Jan 1 12:00:12 cfgmgr(ap): MAC address : 00:14:2b:12:5b:89
Jan 1 12:00:13 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:00:13 cfgmgr(lanbridge0): Bridge Created: br0
Jan 1 12:00:15 cfgmgr(lanbridge1): Bridge Created: br1
Jan 1 12:00:17 cfgmgr(lanbridge2): Bridge Created: br2
Jan 1 12:00:18 cfgmgr(lanbridge3): Bridge Created: br3
Jan 1 12:00:20 cfgmgr(ap): WPA Authenticator Started
Jan 1 12:00:20 cfgmgr(lanbridge0): Bridge Interface Added: eth0
Jan 1 12:00:22 cfgmgr(lanbridge0): Bridge Interface Added: eth1
Jan 1 12:00:24 cfgmgr(lanbridge0): Bridge Interface Added: eth2
Jan 1 12:00:25 cfgmgr(lanbridge0): Bridge Interface Added: eth3
Jan 1 12:00:27 cfgmgr(ap): EEPROM len 473
Jan 1 12:00:27 cfgmgr(ap): Set PIL mode (1)
Jan 1 12:00:27 cfgmgr(ap): AP Driver configuration successful
Jan 1 12:00:39 cfgmgr(ap): AP IS UP
Jan 1 12:00:40 cfgmgr(sar): DSL Carrier is training
Jan 1 12:00:40 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:00:41 cfgmgr(ap): AP Releasing Lock
Jan 1 12:00:41 cfgmgr(ap): AP Sending IFACE UP
Jan 1 12:00:41 cfgmgr(lanbridge0): Bridge Interface Added: wlan0
Jan 1 12:00:50 cfgmgr(sar): DSL Carrier is training
Jan 1 12:00:50 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:01:00 cfgmgr(sar): DSL Carrier is down
Jan 1 12:01:00 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:06:00 cfgmgr(sar): DSL Carrier is training
Jan 1 12:06:00 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:06:10 cfgmgr(sar): DSL Carrier is training
Jan 1 12:06:10 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:08:50 cfgmgr(sar): DSL Carrier is training
Jan 1 12:08:50 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:09:00 cfgmgr(sar): DSL Carrier is training
Jan 1 12:09:00 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:09:10 cfgmgr(sar): DSL Carrier is training
Jan 1 12:09:10 cfgmgr(pppoe-107): del_iptable_rules : ppp_name not intact
Jan 1 12:13:20 cfgmgr(sar): DSL Carrier is up
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.35)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.32)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.40)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.36)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.38)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_default oamPing(0.96)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_search oamPing(0.35)result(2)
Jan 1 12:13:20 cfgmgr(sar): auto_vcc_search oamPing(8.35)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(0.43)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(0.51)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(0.59)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(8.43)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(8.51)result(2)
Jan 1 12:13:21 cfgmgr(sar): auto_vcc_search oamPing(8.59)result(2)
Jan 1 12:13:22 cfgmgr(pppoe-107): Max Connection Delay 60
Jan 1 12:13:22 cfgmgr(pppoe-107): Conn Delay Timer started for 3 sec
Jan 1 12:13:25 cfgmgr(pppoe-107): PPPoE Launch after conn delay timeout ...
Jan 1 12:13:26 pppd[375]: pppd 2.4.4 started by root, uid 0
Jan 1 12:13:26 pppd[375]: Sending PADT for de19 before starting new discovery
Jan 1 12:13:26 pppd[375]: Server MAC is: 00-90-1a-a1-ea-1c
Jan 1 12:13:26 pppd[375]: Got connection: 7529
Jan 1 12:13:26 cfgmgr(pppoe-107): Saving PPPoE Session ID: 0x7529
Jan 1 12:13:26 cfgmgr(pppoe-107): Received pppoe server mac: 0x00-90-1a-a1-ea-1c
Jan 1 12:13:26 pppd[375]: Saved Session ID: 0
Jan 1 12:13:26 pppd[375]: AC MAC address: 00-90-1a-a1-ea-1c
Jan 1 12:13:26 pppd[375]: Connect: ppp0 {--} nas0
Jan 1 12:13:27 pppd[375]: PAP authentication succeeded
Jan 1 12:13:27 pppd[375]: local IP address 90.189.231.183
Jan 1 12:13:27 pppd[375]: remote IP address 213.228.116.8
Jan 1 12:13:27 pppd[375]: primary DNS address 217.70.106.5
Jan 1 12:13:27 pppd[375]: secondary DNS address 217.70.96.34
Jan 1 12:13:27 cfgmgr(pppoe-107): PPPoE Connect with IP Address 90.189.231.183
Jan 1 12:13:27 cfgmgr(pppoe-107): PPPoE Connection Successfully Established
Jan 1 12:13:27 cfgmgr(pppoe-107): sys_send_event - pppoe up
Jan 1 12:13:27 cfgmgr(pppoe-107): PPPoE Connect with Gateway IP Address: 213.228.116.8
Jan 1 12:13:28 syslog: dproxy force reload config.
Jan 1 12:14:27 cfgmgr(logic): UDP connections reset...
Jan 1 12:14:37 cfgmgr(logic): UDP connections flush...
Evgenius
СообщениеДобавлено: Пн 1-02-10 : 23-31    Заголовок сообщения: Ответить с цитатой
сейцас потерялся и подключился вообще на 2,5 мегабитах Sad
Evgenius
СообщениеДобавлено: Вт 2-02-10 : 10-54    Заголовок сообщения: Ответить с цитатой
прошла ночь,по утру прошился всё норм...
