Арчи Митич Начинающий |
Добрый день.
Пользуюсь широкополосным интернетом вот уже полгода. Но скорость что-то не очень устраивает. После подключения установили скорость на модеме 7168/716 Кб/с. Но в реале намного ниже по данным AIDA64 скорость входящего 250-300 КБ/с (~1600-2400 Кб/с) исходящего 4-6 КБ/с (~32-48 К/c). Параметры линии
noise margin upstream: 14 db
output power downstream: 19 db
attenuation upstream: 14 db
tone 0- 31: 00 00 00 27 89 9a ab bb bb bb bb aa 99 99 77 00
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 14 db
output power upstream: 12 db
attenuation downstream: 26 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: 00 00 00 00 02 34 55 66 77 78 89 99 9a ab bb bb
tone 64- 95: 0b bb bb bb bb bb bb bb bb bb aa aa aa aa aa aa
tone 96-127: aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa
tone 128-159: aa aa a9 9a 99 99 99 99 99 99 99 99 99 99 99 99
tone 160-191: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99
tone 192-223: 99 99 99 99 99 89 88 98 88 88 88 88 88 88 88 88
tone 224-255: 88 88 88 88 88 88 88 88 88 88 88 88 88 87 77 75
Что означают параметры линии
Каковы их значения для нормальной работы.
Спасибо! |
Peplove Эксперт |
друг это тебе надо к профи, а профи тут один которого я знаю это rendy он поможет.
и не верь всему что написано в аидах не всё что написано на нулях и единицах идеально ,они могут и ошибатся .
"После подключения установили скорость на модеме 7168/716 Кб/с." это профиль скорость порта к которому мопед цепляется звони в тех поддержку и проси его поднять,если есть вожможность подымут,та а тариф у тебя какой?случаем не "Земля" а он раньше и был где то так по скорости это сейчас подняли до до 5 Мбит/с главное тут это "до" тоесть не обязательно что будет постоянно такая скорость.ну если будут ещё вопросы обратись к rendy он спец по тонам. |
aleks4634 Эксперт |
Арчи Митич
а тарифный план то какой? Может ты из направления Интернет с такой скоростью скачиваешь? ты из области (если да то....)? Судя по твоей статистике, параметры линии довольно таки не плохи, можно поставить профиль и в 12 мегабит и далее (если конечно поставят). Аида ни о чем, реальная скорость на торрент трекере. |
rendy Гуру |
aleks4634 Эксперт |
потому что может не поддерживать атс\ртк\линия\модем\руки |
rendy Гуру |
aleks4634
3-4 отбрасываем, остается 1,2 или 5 |
BouH Продвинутый форумчанин |
rendy писал(а): |
aleks4634
Второе тоже отбрасываем - вряд ли в Белоруси РТК |
aleks4634 Эксперт |
BouH
а с чего в Белоруссии?
// с того что юзер пишет с провадера infonet.by |
aleks4634 Эксперт |
красный шрифт
Блин...извиняюсь за свою глупость( |
nethello Гуру |
Батька не даёт много интернета. |
