Big Digger Гуру
onOne Software MASK PRO 4.0 - of Masking Tools for Photoshop.
In 2005, onOne Software acquired several Adobe Photoshop plug-ins and QuarkXPress XTensions from Extensis, Inc. and Lizard Tech and relaunched them under the onOne Software brand.
Portland, OR — December 6, 2006 — onOne Software, Inc., announces today that Mask Pro 4 — the upgrade to the company's popular digital image masking plug-in Mask Pro 3 - is now shipping.
Mask Pro 4 provides a complete collection of Photoshop plug-in tools that allow users unprecedented flexibility when tackling the most challenging masking job. And this new version focuses on teaching the user how to best use this comprehensive toolset for masking a wide range of images.
As in the previous version, onOne Software's Mask Pro 4 uses the concept of "keep colors" and "drop colors" chosen by the user and then based on those user selections, the Mask Pro 4 algorithm will remove only those selected colors from an image. One of the strengths of Mask Pro 4 is that when a "drop color" is found in another pixel, Mask Pro 4's powerful color decontamination technology will remove only that color value from the pixel, leaving that pixel (or pixels) semi-transparent. The benefit to the user is that Mask Pro 4 will virtually eliminate the edge halo effect often seen when masking a transparent object or edge.
Recognizing that masking digital images can be a time-consuming job regardless of the tools used, Mask Pro 4 focuses on teaching users how to effectively complete a masking job through built-in video tutorials that detail how each tool works and when to use it.
Additional new features in version 4 include:
- New Keep/Drop detail view showing users the exact color values selected by the Keep & Drop Highlighters. Support for Wacom Pen Tablets including pressure sensitivity. If a user presses hard with their pen, they will get a hard edge to their mask. If they press lightly, they will get a soft, subtle edge to their mask. Improved Navigator windows allow users to see several views while masking a subject. The different views include a composite mode so users can see the new background appear as they mask allowing them to make immediate decisions on their mask and an Alpha channel view so they can see in black and white (and grey) how their mask will look.
Скачать: http://file.risp.ru/get/file/?id=51526 |
