Annex M
Ответить на тему    Форум АДСЛ КлубаМОДЕМЫ, ПРОШИВКИ, ИНСТРУКЦИИZYXEL
port
СообщениеДобавлено: Вс 1-11-09 : 18-01    Заголовок сообщения: Ответить с цитатой
Днем позвонил в тех. поддержку, сказал что модем не может переключиться в annex m. Заявку приняли, через час исходящая поднялась до 180 кб, интересно это предел? Модем все равно показывает модуляцию adsl2plus.
прошивка
ZyNOS F/W Version: V3.40(ALO.0) | 09/27/2006 последняя на оф. сайте
"DSLAM - Alcatel" это вопрос? И как узнать Alcatel или нет?
noise margin upstream: 14 db
output power downstream: 16 db
attenuation upstream: 21 db
carrier load: number of bits per symbol(tone)
tone 0- 31: 00 00 00 06 89 bb cc cc cc dd dd dd dd dd dd dc
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 12 db
output power upstream: 14 db
attenuation downstream: 31 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: cc cc cc bb bb ba aa aa a9 98 87 65 40 00 00 00
tone 64- 95: 22 34 45 55 56 66 77 77 78 87 88 88 99 99 89 90
tone 96-127: 89 9a a8 aa 99 9a 99 99 98 99 98 89 98 88 98 99
tone 128-159: 99 99 99 89 99 9a 99 a9 aa 99 a9 99 aa 99 9a 99
tone 160-191: a7 9a 99 99 99 99 99 99 99 99 9a 99 99 99 99 a9
tone 192-223: 89 98 98 88 89 89 88 88 98 88 89 88 89 88 88 88
tone 224-255: 98 98 88 88 88 88 89 98 88 98 98 88 98 88 88 88
tone 256-287: 88 88 88 88 88 87 88 87 77 87 77 88 77 67 67 67
tone 288-319: 66 56 56 54 44 44 33 34 44 54 45 65 66 66 55 66
tone 320-351: 66 56 65 66 66 56 66 55 56 65 55 55 56 55 54 45
tone 352-383: 54 44 54 44 45 44 44 34 34 43 32 22 22 22 22 22
tone 384-415: 22 22 22 22 22 22 22 21 10 00 00 00 00 00 00 00
команда w dmt2 show cmsg1
C-MSG1
TARSNRMds = 120 dB
MINSNRMds = 0 dB
MAXSNRMds = 511 dB (Excess margin need not to be minimized)
RA-MODEds = 2 (RATE ADAPTIVE AT INIT)
PM-MODEds = 1 0 (L2 is allowed) (L3 not allowed)
RA-USNRMds = 0 dB
RA-UTIMEds = 0 sec
RA-DSNRMds = 0 dB
RA-DTIMEds = 0 sec
BIMAXds = 15 bit
EXTGIds = 0 dB
CA-MEDLEYus = 6144 symbols(min)
Reserved1 = 0 (Should be 0)
команда w dmt2 show cparams
D2 = 1
L2 = 0
- Path #3 -
M3 = 0
T3 = 0
R3 = 0
D3 = 1
L3 = 0
%%%Check Table 7-19 Constraint
Valid M[0]=8
Valid T[0]=7
Valid R[0]=16
Valid D[0]=8
Valid L[0]= 512
Valid S[0]= 3.75
Valid OR[0]= 9.75 kbits/sec
Valid Delay[0]= 7.00
Valid msg[0]= 6.82 kbits/sec
Invalid net_data_rate[0]= 475.42 bits/sym(min=625, max=1020)
Valid Per[0]= 16.40 ms
Valid INP[0]= 1.00
команда w dmt2 show rparams
D2 = 1
L2 = 0
- Path #3 -
M3 = 0
T3 = 0
R3 = 0
D3 = 1
L3 = 0
Valid M[0]=1
Valid T[0]=1
Valid R[0]=10
Valid D[0]=64
Valid L[0]= 2131
Valid S[0]= 0.95
Valid OR[0]= 33.42 kbits/sec
Valid Delay[0]= 15.50
Valid msg[0]= 30.67 kbits/sec
Invalid net_data_rate[0]= 2039.07 bits/sym(min=625, max=1020)
Valid Per[0]= 17.47 ms
Valid INP[0]= 1.20
rendy
СообщениеДобавлено: Вс 1-11-09 : 18-15    Заголовок сообщения: Ответить с цитатой
port
DSLAM, судя по всему, Alcatel, в остальном - что и требовалось доказать. Annex M в данном случае включён и работает, но:
1)target SNR Margin = 12 - больше мощность, ниже скорость. Стандартные значения - 6.
2)кривой профиль с адаптацией по startup без настройки дополнительных параметров - опять же лёгкий способ урезать скорость и попытка увеличить стабильность без дополнительных настроек профиля.
3)INP по исходящему каналу - 1, текущая interleaved delay = 7. Если смотреть по табличке topic40650 , то скорость должна быть максимум 1792, но это в идеальных условиях и при target 6. INP по исходящему каналу следовало бы уменьшить до 0,5, target SNR Margin - до 6, профайл выставить динамический.
О других параметрах исходящего канала ничего не могу сказать, нужно звонить в техподдержку и разбираться.
Какая сейчас скорость подключения?
Ответить на тему    Форум АДСЛ КлубаМОДЕМЫ, ПРОШИВКИ, ИНСТРУКЦИИZYXEL Часовой пояс: GMT + 7
Страница 2 из 2
