Windows 7 RTM
На страницу 1 2 3 ... 39 40 41
ViPER
СообщениеДобавлено: Чт 29-10-09 : 01-45    Заголовок сообщения: Ответить с цитатой
andrey2002
создай батник с содержимым и запусти
Код:
@echo off
cls
rem [Step 1]
echo Microsoft (R) Windows Software Licensing.
echo Copyright (C) Microsoft Corporation. All rights reserved.
echo+
echo Step 1: Select Windows(R) 7 edition.
echo+
echo+
echo This tool can help you activate one of the following Windows(R) operating systems:
echo A) Windows(R) 7 Professional
echo B) Windows(R) 7 Professional N
echo C) Windows(R) 7 Enterprise
echo D) Windows(R) 7 Enterprise E
echo E) Windows(R) 7 Enterprise N
echo+
echo F) {Skip this step}
echo+
echo+
choice /C ABCDEF /N /M "Select one of the options above (A-F):"
IF ERRORLEVEL 6 goto :step2
IF ERRORLEVEL 5 goto :entn
IF ERRORLEVEL 4 goto :ente
IF ERRORLEVEL 3 goto :ent
IF ERRORLEVEL 2 goto :pron
IF ERRORLEVEL 1 goto :pro
:pro
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ipk FJ82H-XT6CR-J8D7P-XQJJ2-GPDD4
pause
goto :step2
:pron
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ipk MRPKT-YTG23-K7D7T-X2JMM-QY7MG
pause
goto :step2
:ent
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ipk 33PXH-7Y6KF-2VJC9-XBBR8-HVTHH
pause
goto :step2
:ente
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ipk C29WB-22CC8-VJ326-GHFJW-H9DH4
pause
goto :step2
:entn
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ipk YDRBP-3D83W-TY26F-D46B2-XCKRJ
pause
:step2
rem [Step 2]
cls
echo+
echo Step 2: Select Key Management Service (KMS) host.
echo+
echo+
echo The system time on the client computer must match the system time
echo on the KMS host.
echo You might need to change the time on your computer manually.
echo+
echo    KMS Host                        Time Zone
echo A) kmsr2.dynalias.com:1688         UTC +2
echo B) 194.0.116.18:1688               UTC +2
echo C) vault-tec.no-ip.org:1688        UTC +3
echo D) 78.24.72.119:1688               UTC +2
echo+
echo E) {Skip this step}
echo+
echo+
choice /C ABCDE /N /M "Select one of the options above (A-E):"
IF ERRORLEVEL 5 goto :step3
IF ERRORLEVEL 4 goto :kms4
IF ERRORLEVEL 3 goto :kms3
IF ERRORLEVEL 2 goto :kms2
IF ERRORLEVEL 1 goto :kms1
:kms1
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -skms kmsr2.dynalias.com:1688
pause
goto :step3
:kms2
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -skms 194.0.116.18:1688
pause
goto :step3
:kms3
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -skms vault-tec.no-ip.org:1688
pause
goto :step3
:kms4
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -skms 78.24.72.119:1688
pause
:step3
rem [Step 3]
cls
echo+
echo Step 3: Activation.
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -ato
pause
rem [Step 4]
cls
echo+
echo Step 4: Activation Status Check
echo+
echo+
echo Checking Windows activation status...
echo+
echo+
"%SystemRoot%\system32\cscript.exe" "%SystemRoot%\system32\slmgr.vbs" -dli
pause
igor1533
СообщениеДобавлено: Пт 20-11-09 : 22-42    Заголовок сообщения: Ответить с цитатой
если кто еще не видел -- http://habrahabr.ru/blogs/windows7/75384/ (активация винды)
Сейчас хакеры нашли вариант полного обхода механизма Windows Activation Technologies (WAT) без манипуляций с BIOS'ом и вообще без использования ключа активации.
С помощью этого метода блокируется работа модулей SPP (Software Protection Platform) и SLC (Software Licensing Client). И хотя 30-дневный счётчик периода активации может продолжать видимость работы, он уже не инициирует никаких действий. Для блокировки используются следующие команды:
takeown /F %WINDIR%\System32\sppcomapi.dll
icacls %WINDIR%\System32\sppcomapi.dll /deny *S-1-1-0:F
Здесь sppcomapi.dll — библиотека, которая контролируется основную часть функций SPP. Метод применим для операционных систем Windows 7 и Windows Server 2008 R2.
wint
винтанутый модератор
СообщениеДобавлено: Вс 6-12-09 : 14-19    Заголовок сообщения: Ответить с цитатой
прошил биос матери giga p55ud3 для активации виндовс 7.при запуске slmgr -ilc C:\GIGABYTE-GBT-2.1.XRM-MS и slmgr -ipk 22TKD-F8XX6-YG69F-9M66D-PMJBM пишет мол винда активирована,а при просмотре 30 дней(уже 26)
как мне победить ее?
на всякий случай выложу биос
P55UD3.rar
Скачать
 Размер файла:  758.85 KB
 Скачано:  165 раз(а)
ViPER
СообщениеДобавлено: Вс 6-12-09 : 18-00    Заголовок сообщения: Ответить с цитатой
первым делом нужно узнать тот ли биос у тебя.
http://napalum.ifolder.ru/14794326
скачай, выбери Advanced Mode если предлагает и сделай скрин окна проги
wint
СообщениеДобавлено: Вс 6-12-09 : 18-35    Заголовок сообщения: Ответить с цитатой
вот
 Размер файла:  125.31 KB
 Просмотрено:  197 раз(а)
ViPER
СообщениеДобавлено: Вс 6-12-09 : 18-46    Заголовок сообщения: Ответить с цитатой
Биос кривой, шил чем? Под виндой? Если нет то шей через "@Bios" на сайте производителя есть где то.
И шей вот этим биосом.
GA-P55-UD3_F5_GIG21.zip
Скачать
 Размер файла:  782.83 KB
 Скачано:  163 раз(а)
wint
СообщениеДобавлено: Вс 6-12-09 : 18-58    Заголовок сообщения: Ответить с цитатой
ViPER
шил в биосе ф8 с флешки
а то что винда ультима,а не интерпрайз,не косяк?
ViPER
СообщениеДобавлено: Вс 6-12-09 : 19-02    Заголовок сообщения: Ответить с цитатой
wint
нет, причём тут Enterprise? мы говорим про активацию OEM SLP
СообщениеДобавлено: Чт 17-12-09 : 20-07    Заголовок сообщения: Ответить с цитатой
Перестали работать гаджеты рабочего стола-вырубаются после загрузки системы. Попробовал создать вторую учётную запись-там всё работает. Что это может быть?
MAXXX
Music на ftp
СообщениеДобавлено: Чт 11-03-10 : 18-02    Заголовок сообщения: Ответить с цитатой
Скажите, как убрать из списка воспроизведения windows media player отображение оценок (звездочек), когда ратягиваешь названия трека?
раздражает до ужаса еще и названия всего микса не видно...
2 pac
СообщениеДобавлено: Пт 21-05-10 : 12-59    Заголовок сообщения: Ответить с цитатой
igor1533
za toboi uje viehali
СообщениеДобавлено: Сб 29-05-10 : 20-40    Заголовок сообщения: Ответить с цитатой
Баян Воспользуйся другим, хотя бы, аналогичным плеером.
СообщениеДобавлено: Пт 24-09-10 : 13-27    Заголовок сообщения: Ответить с цитатой
Windows 7 - 7600 x64 ru OEM Ultimate 7600 Original
http://rutracker.org/forum/viewtopic.php?t=3169952
Также имёются
Windows 7 x64 eng Original] http://rutracker.org/forum/viewtopic.php?t=3170795
Windows 7 x32 (x86) ru Original] http://rutracker.org/forum/viewtopic.php?p=38319500
Windows 7 x32 (x86) eng Original] http://rutracker.org/forum/viewtopic.php?t=3170799
2 pac
СообщениеДобавлено: Вс 5-12-10 : 20-02    Заголовок сообщения: Ответить с цитатой
активация
нынче слетела. Есть уже новые крякеры?
Страница 41 из 41
